Picture, details of toe/camber correction subframes
ian332isport
Post Mon May 28, 2007 8:37 pm
Jhonno wrote:yeah yeah, dont get me wrong, i understand how it works, but im sayin the pic Ian posted of the beam, has the tabs welded on wrong to achieve the desired result
Aaah, I see what you're saying now. You are looking at the slot the head of the eccentric bolt slides in, not the slot the bolt itself slides in. They are at 90 degrees to each other.
If you look at the slot the bolt physically passes through, you will see the inner bolts go up and down, and the outer bolts go forward and back. It's hard to visualise what the eccentric bolt does when you turn it, but when it's in front of you, it's very simple.
Ian.
superclarkey
Post Mon May 28, 2007 8:39 pm
yeah, its like a cam.
Post Mon May 28, 2007 8:40 pm
I am there now.. :o: :o: :o:
Dont worry, managed to confuse myself with how the pic was taken. Cheers guys
Cant believe even Dave got it before i did :o: :cry: :cry:
d6dph
Post Mon May 28, 2007 8:42 pm
Cheek of it, Luckily I'm not quite as stupid as I look :P
superclarkey
Post Mon May 28, 2007 8:53 pm
lucky i can't see you to see how suptid that is
joke :mad:
superclarkey
Post Mon May 28, 2007 8:57 pm
glad you got it, i'm having a buch of these things made, so i may well offer some axles on an exchange basis for anyone interested.
Going to see how much it costs to make a few, maybe do a few with adjustable rose joint rear trailing arms, they would be worth a nice bit of money to the right person as its a full race car set up, will do all the bracing too.
going to pick up 2 axles tomorrow to mod. see how i get on like. i may find i could modify it a bit to get more. as i've found some bigger camber bolts in my parts catalog, so could redsign to give more range.
clakrey.
Post Tue May 29, 2007 2:34 am
d6dph wrote:Cheek of it, Luckily I'm not quite as stupid as I look :P
god!! then we would be in trouble!! :wink: 8O :P
superclarkey
Post Tue May 29, 2007 3:19 am
Just did a bit of simple maths, if i do double slot in same direction for camber only, and i center the weld on plates in the center of the exsisting holes.. so it basicly has a plus and minus range... i worked out there is around 1.2degrees of adjustment.... no were near enough.
IF i weld them on, so they don't have a minus and only plus to remove camber, ie. the plates are welded on so the very start of there travel before adjustment is stock setting... i can gain nearly 3degrees of adjustment... but can't add any more camber that it has now (not that i would want to, this is why i'm surgesting this option)
i think 3 degrees of correction is min, for those that only have one side of correction, i think 1.5 degrees is as much as you'll be able to remove if that.
the other limitation is the fact that you can higher the trailing arm up away from the sumframe as much as you want, but you can't lower it that much on the otherside without hitting the subframe ect.
So now i understand why there in the kit you recived it had one side different with massive slot, totaly makes sence, because they know the adjustment is very small, this would give you nearly 2degees of neg removal, and also why the camber slots are the inside..as you can move up away from the subframe as much as you want.
In short, on the one you've made, i think your going to be suprised at how little you can remove... but if your only trying to take some out, then it will do what you want.
As you can tell, i'm after making a kit that is basicly capable of removing neg and gettig it to 0degrees... that way i have range from 0-3degree neg.
these are my aims, i may well take you up on the offer of the camber kit you have, as a i will defo need to make something like this, maybe make better camber bolt for it or something.
clarkey.
gareth
Post Tue May 29, 2007 10:42 pm
i've been playing with ideas for toe / camber correction lately and modelled up the geometry of the trailing arm in 3D cad.
i based the model on a 50mm drop. this gives 0.22° toe-in per wheel. and 1.8° negative camber.
the eccentric bushes (1mm offset bmw ones) can correct up to a maximum of 0.35° of camber or toe but not both to that extent.
to correct my 1.8° camber, i'd need to move one pivot point by 10.3mm
hope that helps :D
link to my thread: http://www.e30zone.net/modules.php?name ... ic&t=68485
superclarkey
Post Tue May 29, 2007 11:00 pm
Yeah i basicly saw that these bolts give about 4mm +- (8mm movement over all) and as you surgested i worked out that even if i set them so they were both working on camber alone... they would not knock out more then about 2degees.
So yes the inner would need to lift by at least 8mm and the outter droped by the 4mm... that would give around what you need.
I've ordered the 20mm id rod ends for the trailing arms.
ian332isport
Post Tue May 29, 2007 11:03 pm
superclarkey wrote:I may well take you up on the offer of the camber kit you have
No probs :D
gareth
Post Tue May 29, 2007 11:08 pm
i might just weld on a modified bracket for a set 10mm lift on the inner joint and tweak from there if necessary with the eccentric bushes...
superclarkey
Post Wed May 30, 2007 12:10 am
see how you get on :)
either way, i've got to do the trailing arms, as i want full control over the toe in.
clarkey.
ian332isport
Post Wed May 30, 2007 12:21 am
superclarkey wrote:see how you get on :)
clarkey.
I still reckon your tyre wear is camber induced. Surely that much toe in would be wearing the outside edge, not the inner ?
Saying that, you deffo have toe problems that me be causing odd handling.
Ian.
superclarkey
Post Wed May 30, 2007 12:35 am
well, i kinda understand whats going as i own a R32 skyline too, with adjustable rear arms... i've played about with set up quite a bit and i know what wears tyres.. camber wears tyres if skidding... but you can run loads of camber with 0 toe with nearly no wear at all.
but if you run like .7degrees neg and 1 degree of toe in... the were is silly.
and i am wearing the outside of the tyre too... but only when drifting hard on the lock.
Toe is the problem... thats for sure. Think about it... camber if parrell shouldn't wear... toe wears because its always scrubbing trying to narrow its track.
but i'm not dissagreeing with you, i'm just experssing my findings over the yearts of racing the skyline.
clakrey.
superclarkey
Post Wed May 30, 2007 12:38 am
The other interesting thing to think about... think how much mpg you loose form toe in on the bmw... youj ever tryed to push a bmw around ?? it feels like a million tons... you push a skyline about with 0 toe all round and it rolls off into the distance on its own!
i noticed, that in the bmw regardless, i have to keep a bit of throttle on alll the time as it slows down so quickly on its own, the skyline rolls for miles and before yousasy it they are nearly the same weiht!
i bet you any money when i sort this Toe issue out, my mpg will fly up. as throttle will be less needed in a starit line.
turst me on this one :D
buster
Post Wed May 30, 2007 2:19 pm
I only fitted camber adjustment to mine,i dont think toe needs doing unless its previously crash damaged.
Heres mine,before paint:
Karan
Post Wed May 30, 2007 2:29 pm
Hi Ian hows things
just noticed this and i think its probably the most important thing to right on an e30 cos thats what makes the on limit handling at high speed so crap especially if ure into drifting
i also think clarkeys right with wanting to get the toe nr parallel as ive played with my s14 a lot now as the whole rear serup is adjustable with the arms i have put on it, and when i got rid os the stock toe in the change in the charcter of the car was amaaaaaaazing!!
im trying to wonder how much adjustment ure gonna get on those tabs though, do u think u could acheive parallel toe and maybe -1.5 deg camber with that much adjustment as if u could id really love to do this on mine
Karan
Post Wed May 30, 2007 2:30 pm
its the combination of the camber and toe that wears the tyres out i think....but i actually think the toe is the worse culprit especially when coupled with the insane camber slammed e30s have!
ian332isport
Post Wed May 30, 2007 2:51 pm
Karan,
I'm hoping to get all this fitted in the next week or two before a trip to the ring, so I'll report back when I've had the geometry checked/setup. I'm only looking to return things to standard (non lowered) settings, so I'm pretty sure I will have enough adjustment.
I don't have horrendous rear, inner tyre wear, but it does wear quicker than the outside. I suspect it ultimately looses a bit of grip as well, but I don't really have any handling problems I'm aware of.
It's going to be hard to say if the geometry change alone has made a difference, as I'm replacing pretty much everything on the underside of the car (bushes, bearings, pipes, hoses, fuel tank, control arms, rear brakes and just about every nut, bolt & washer as well). I'm also fitting H&R ARB's and a bunch of ARB mounting point strengthening parts. It will hopefully drive better than new when it's all fitted 8)
Cheers,
Ian.
Karan
Post Wed May 30, 2007 3:05 pm
u running stock arbs at the moment ian? they will really help, and i really think ull be surprised when u set the geometry.... no more understeering e30 syndrome, losing the rear toe due to lowering really makes the front end turn in better and feel go kart like :cool:
when i put the hartge arbs on the sport they were luuuuuurvely
superclarkey
Post Wed May 30, 2007 5:03 pm
this is why welded diffs work on skylines and 200ssx... put one on a BMW and its wank. toe is not your friend.
as i've pointed out before... to get rid of the toe, i'm going to rose joint the trailing arms :D
ian332isport
Post Wed May 30, 2007 7:02 pm
Karan wrote:u running stock arbs at the moment ian?
It's all stock apart from the Billies (inverted 8) ), H&R springs, Powerflex trailing arm bushes and M3 offset control arm bushes.
I'm also fitting some adjustable camber plates (Ireland Engineering street plates) to give a bit more negative camber on the front during track days and ring visits. This will hopefully help to save the outer edges of my front tyres, although I do now have a set of track wheels (more BBS RC's), so not quite the issue it was.
I really am looking forward to see how it performs. Everything I'm doing should tighten it all up, but not upset the ride. The Z1 rear discs should help the braking as well.
Ian.
gareth
Post Wed May 30, 2007 9:58 pm
where is the best place to get an adjustable rear beam kit? does anyone in the uk do one?
does anyone know hom much adjustability the E39 offset bolts will achieve?
superclarkey
Post Thu May 31, 2007 1:10 pm
if you can wait a little bit, i'm planning on doing a few beams on a exchange bassis ready to go and poweder coated.
Going to do a few see what it costs me and let ytou guys know ;D will give the option of powerflex bushes or stock bushes pressed in too.
Just made a jig to do it, so each one will be the same no questions.
clarkey.
superclarkey
Post Thu May 31, 2007 11:00 pm
Just to let you guys know, i raised the car by 20mm, and the toe is about half what it was, and camber is no were near as bad.
goes to prove that a few more mm can make all the difference.
tpg
Post Fri Jun 01, 2007 5:12 pm
Hello,New on here.Can anyone confirm these part numbers for me please?All to do with this topic.They are the E39 bolts,washers and nuts.I've been given 33321095102 for the bolt.33321092310 for the washer.33326760668 on the nut.
Its threads and info like this that makes me happy to get into E30's again.For info I am doing "Another"335i conversion on an '88 converatdribble.I've broken a later 325 Tourer from someone on here for its ABS and varoius other bits and pieces.I have a 735i lent up against the side of the house looking after the engine and 'box.And its and auto...The future is Low and lazy.
Thanks.
Richard.
Gwynne26
Post Fri Jun 01, 2007 5:24 pm
Had the wheel alignment on my cab measured. Ultratyres in Amstelveen are the business as they have the right kit and check all four together. All four point in slightly different directions but the front toe in was adjusted, had been feathering the front tyres. The steering's now much more planted and firmer, and the car is a little easier to push. Not a lot better on the fuel economy, just cheaper on tyres.
MJG
Post Sat Jun 02, 2007 2:50 pm
Clarkey let me know about your subframes dude, I might want you to make one for my e30 if/when I buy it back off Nick (PS - don't nick my Spaxes from that).
It has horrible camber, and I want to lower it more when I get 5 stud and my 17x10s arrive :mad: so having camber/toe adjustment would rock it out.
I'll provide you with a subframe with trailing arms, and can come down and do the work on it myself if you let me - you can just do the welding so my trailing arms don't fall off on my way out the workshop lol.
How do you plan on fitting rosejoints btw? I've seen them on the underside of a tubular trailing-arm'd m3 before but not on standard arms.
MJG
Post Sat Jun 02, 2007 3:16 pm
Aha, like this for rosejoints then....
Found on this cool little set of photos :)
http://www.passracing.com/project_e30_m3.htm
alwaysideways
Post Sun Jun 03, 2007 3:33 am
yes!!! :D
Talk about perfect timing. I am just about to rebuild my front AND rear suspensions, but i was thinking it would be above me to upgrade the rear geometry. thank you.
i am so happy. Tho i wont hump ya... :wink:
superclarkey
Post Sun Jun 03, 2007 12:56 pm
MJG, i thought we shared are parts of bmw's ;)
Yes just like the pictures mate, that is what i'm going to do, i think it wouldn't be that expensive to do, and it would be a fair tirck mod... as the E30 is a very good car but its very under designed weak as fuck rear axle really lets it down a fair bit, because your not going to rag it on stock suspention are ya. lo
l
clarkey.
gareth
Post Sun Jun 10, 2007 9:31 am
a heads-up guys...
i've just got my E39 offset bolts and wierd washers from my local dealer. i got the numbers from here: please note... they're wrong!!!!! http://e30m3performance.com/installs/in ... /index.htm
the number he gives for the bolt is actually the correct number for the washer. lucky :D 33-32-1-092-310
the number he gives for the washer turn out to be a M10 offset bolt. incorrect!!! :( 33-32-1-093-456
can anyone please confirm the right numbers please? are the ones in tpg's post corrrect?
tpg wrote:Hello,New on here.Can anyone confirm these part numbers for me please?All to do with this topic.They are the E39 bolts,washers and nuts.I've been given 33321095102 for the bolt.33321092310 for the washer.33326760668 on the nut.
i'll let the site owner know they're wrong once i have confirmation i'm not being a tit!!!! :D
ian332isport
Post Sun Jun 10, 2007 10:16 am
Gareth,
Here you go:
Bolts - 33 32 1 095 102
Washers - 33 32 1 092 310
Nuts - 33 32 6 751 446
The part number above for the nut is from my ETK, but the RealOEM site lists both this number, and the one posted by tpg above. Either would work, and I suspect the 33 32 6 751 446 has been superseded by 33 32 6 760 668.
Cheers,
Ian.
gareth
Post Sun Jun 10, 2007 10:22 am
thanks mate :D
