m42-----S38-----2JZ big single
Gwynleym10
Post Sat Sep 02, 2006 2:46 pm
Splendid! :mad:
London 2 Cape Town
www.Overlandinthesun.com
Post Sat Sep 02, 2006 7:22 pm
Nice work Karan!!! :cool: :cool:
How much did the exhaust/manifold work cost you in the end?
ian332isport
Post Sat Sep 02, 2006 8:46 pm
Excellent news. Glad to hear my wiring chart was correct :cool:
gareth
Post Sat Sep 02, 2006 9:38 pm
all of a sudden my 3.5 M30 doesn't seem so cool.... :D
Andy335Touring
Post Sat Sep 02, 2006 10:53 pm
Nice one Karan, i can't wait to see and hear it running ! :cool:
Karan
Post Sun Sep 03, 2006 12:15 pm
heres some pics of the manifold....cars not gonna be touched for a cpl weeks now cos im busy so its not gonnabe on the road too soon
although ill try my best
MrBroon
Post Sun Sep 03, 2006 12:20 pm
Are there many E30 with M5 engines going about? I know of only 1 other locally.
Regards,
James Westwood
http://www.bmbits.co.uk BMW Parts at upto 50% off dealer prices
IT Security solutions Scotland
WillG
Post Sun Sep 03, 2006 12:33 pm
only other one ive seen is backis M3 i think, dont think ive seen any in a normal e30 shell, VS motors milked 1600 hp out of one of these engines on pump fuel, got to be close to 2000 with nitrous and race fuel
ste
Post Wed Sep 06, 2006 3:58 pm
bigpimpin wrote: You do get a nice warm feeling when it runs for the first time winkeye
That's the oil spraying on your shoes. :D
maxfield
Post Wed Sep 06, 2006 3:59 pm
Lol this will be a monster. And then i guess it will be an awesome drift wagon.
bigpimpin
Post Wed Sep 06, 2006 4:07 pm
:D It was the anger when I realised that the bottom end was totally fooked! :?
www.m3touring.com
Pal318is
Post Wed Sep 06, 2006 9:23 pm
Can't wait to see/hear this, looks amazing..
Pal
Pal
Image[img]http://Image
Karan
Post Wed Sep 06, 2006 10:29 pm
Jhonno wrote:Nice work Karan!!! :cool: :cool:
A LOT....full manifold and exhaust 2.5 inch twin pipes whole way all made from scratch, the did not modif the original one as i suggested originally, they said its better.easier to make one from scratch from their experience with cars like Ian's
they have done an amazing job however and its wortht he money
jaistanley
Post Thu Sep 07, 2006 2:32 pm
Can I be vulgar and ask how much that manifold was Karan? I might get the S50 one done there..
Jai
infusion
Post Fri Oct 27, 2006 12:46 am
this on the road yet ?
A few Q's.....
Could you use the standard 325i transmission mounts ? would that just give you a 10deg twist in the box ?
Did you use the m5 flywheel, oil pan etc ?
You had to shorten the propshaft by how much? Will the box be ok with the standard diff ratio ?
Karan
Post Fri Oct 27, 2006 12:10 pm
it runs but not on road, needs headlights bumpers etc and clutch pipe
im using 325 mounts on my own custon crossmember
using stock m5 fly and sump
box is perfect with e30 diff ratios, but an e30 m3 diff would be too long
front section of prop was shortened a fair bit as engine is far back and the engine box ae very long!
Toby_Unna
Boost Junkie
Post Fri Oct 27, 2006 12:29 pm
good to see this still coming together Karan
we're going to need to swap keys when it's ready for the road :D
ChizFab
Post Fri Oct 27, 2006 7:46 pm
this is pretty sweet!!!!
will make an awesome drift weapon for sure!!! whats the diff?? 2 way?? or the mans choice.....
WELDER :mad:
Now breaking.... e36/e34/e39 all models pm for parts!
infusion
Post Mon Oct 30, 2006 3:44 am
Did you use the 300mm.de engine mounts?? how did the 300mm.de engine mounts go ?
did you have to modify them for the s38 (i think is says that on the site but it was badly translated)
Karan
Post Mon Oct 30, 2006 12:45 pm
yeh they are the .de ones but remade in 10mm thickness and they are not modified for clearance to the manifold as i had the manifold custom built around them
the diff is an e30 3.64 ratio lsd
jonmsm
Post Mon Oct 30, 2006 3:45 pm
Karan, that manifold is just automotive PORN!!!!!!!
WOWZERS! Would love to see your e30 m5 (AND YOURS TOBY) some time, bet they both go like a rocket! hehe. Nothing i love more than a motorsport straight 6... Now all i need is my very own m5... Anyone wanna lend me 2k to buy the one on ebay?!?! LOL
Jon :)
1986 e28 M535i (gone and missed)
1988 e30 320i cab (full resto STILL in progress)
1996 Volvo 850 T-5 estate (280bhp Turbo Nutter), T-5R (my precious)
1966 Fiat 850 saloon & 1970 Sport Coupe
C1 (go-kart)
infusion
Post Mon Oct 30, 2006 9:59 pm
would the getrag 260 off my 325i mount up to a s38 b36 ?
what box do the s38 use? getrag 280 ?
Karan
Post Thu Dec 14, 2006 3:34 pm
no the 260 will not fit
not sure on the code of my gbox but a e30 m3 box will also fit
Andy335Touring
Post Thu Dec 14, 2006 11:49 pm
Karan, whats left to finish it mate ?
Karan
Post Fri Dec 15, 2006 3:28 pm
coolant hoses and modify bonnet to fit
cant get coolant pipes made from amywhere, there isnt enough room to join lots of samco sections up...anyone know anyone who can custom make htese?
gareth
Post Fri Dec 15, 2006 4:16 pm
how about rigid hoses / pipes with a short flexi rubber bit at the end??
buy a load of stainless steel tube, borrow a tig welder, a pipe bender and get playing! an excuse to learn to tig weld?
do you have any pics of the offending areas? might be worth bouncing a few ideas around?
Karan
Post Fri Dec 15, 2006 4:42 pm
will get some up, i toyed with this idea..... very clever and the engine is fairly solid in there so should be do-able
DieselMeister
Post Sat Dec 16, 2006 10:25 am
Or try Pirtek....
Good work Karan. I look forward to seeing and hearing this in the metal.
jaistanley
Post Fri Jan 05, 2007 12:21 am
Dont samco and the like make them to drawings? Knock some up in AutoCAD. You could even make simple patterns using flexi-tubing of the inner diameter you need for the hoses.
They make the pipes by forming the silicone over braid on a simple mold. Normally the mold is a piece of pipe the correct shape and slightly too long (for trimming). It's layed-up and baked to cure if I recall correctly..
Worth a phone call or two to find out?
Jai
M5pilot
Post Fri Jan 19, 2007 11:58 am
What power steering pump have you used?
Karan
Post Sun Jan 21, 2007 7:29 pm
i have used one of an e23, with some mounting modifications
eraserr
Post Sun Jan 21, 2007 9:16 pm
Hello, great work Karan.
I am doing this swap myself and I am interested how long must the propshaft be for the position 3.
Thanks for help!
Karan
Post Fri May 11, 2007 3:43 pm
cars done!!
just needs pas fluid
starts doesnt overheat while standing etc and runs nice and smooth and sounds mental!!!
just drove about 50metres down the road gently
now gotta mot it
pics coming this weekend of what it looks like
oh and i had to cut a small hole in the bonnet for the plenum!! :cool:
Post Fri May 11, 2007 3:46 pm
:twisted: :twisted: :twisted: :twisted: :twisted:
eko
Old timer
Post Fri May 11, 2007 3:47 pm
Karan wrote:cars done!!
Weekend,fooking hell thats ages to wait 8O
Seriously,fair play mate :D
