m42-----S38-----2JZ big single
Gwynleym10
Splendid!
- Homo Hair
Nice work Karan!!!
How much did the exhaust/manifold work cost you in the end?
ian332isport
Excellent news. Glad to hear my wiring chart was correct
gareth
all of a sudden my 3.5 M30 doesn't seem so cool....
Andy335Touring
Nice one Karan, i can't wait to see and hear it running !
Karan
heres some pics of the manifold....cars not gonna be touched for a cpl weeks now cos im busy so its not gonnabe on the road too soon
although ill try my best
MrBroon
Are there many E30 with M5 engines going about? I know of only 1 other locally.
Regards,
Regards,
James Westwood
http://www.bmbits.co.uk BMW Parts at upto 50% off dealer prices
IT Security solutions Scotland
WillG
only other one ive seen is backis M3 i think, dont think ive seen any in a normal e30 shell, VS motors milked 1600 hp out of one of these engines on pump fuel, got to be close to 2000 with nitrous and race fuel
ste
That's the oil spraying on your shoes.bigpimpin wrote: You do get a nice warm feeling when it runs for the first time
maxfield
Lol this will be a monster. And then i guess it will be an awesome drift wagon.
bigpimpin
ste wrote:That's the oil spraying on your shoes.bigpimpin wrote: You do get a nice warm feeling when it runs for the first time
Pal318is
Can't wait to see/hear this, looks amazing..
Pal
Pal
Pal
[img]http://
[img]http://
Karan
Jhonno wrote:Nice work Karan!!!![]()
A LOT....full manifold and exhaust 2.5 inch twin pipes whole way all made from scratch, the did not modif the original one as i suggested originally, they said its better.easier to make one from scratch from their experience with cars like Ian's
they have done an amazing job however and its wortht he money
jaistanley
Can I be vulgar and ask how much that manifold was Karan? I might get the S50 one done there..
Jai
Jai
infusion
this on the road yet ?
A few Q's.....
Could you use the standard 325i transmission mounts ? would that just give you a 10deg twist in the box ?
Did you use the m5 flywheel, oil pan etc ?
You had to shorten the propshaft by how much? Will the box be ok with the standard diff ratio ?
A few Q's.....
Karan
it runs but not on road, needs headlights bumpers etc and clutch pipe
im using 325 mounts on my own custon crossmember
using stock m5 fly and sump
box is perfect with e30 diff ratios, but an e30 m3 diff would be too long
front section of prop was shortened a fair bit as engine is far back and the engine box ae very long!
Toby_Unna
- Boost Junkie
good to see this still coming together Karan
we're going to need to swap keys when it's ready for the road
ChizFab
this is pretty sweet!!!!
will make an awesome drift weapon for sure!!! whats the diff?? 2 way?? or the mans choice.....
WELDER
WELDER
Now breaking.... e36/e34/e39 all models pm for parts!
infusion
Did you use the 300mm.de engine mounts?? how did the 300mm.de engine mounts go ?
did you have to modify them for the s38 (i think is says that on the site but it was badly translated)
Karan
yeh they are the .de ones but remade in 10mm thickness and they are not modified for clearance to the manifold as i had the manifold custom built around them
the diff is an e30 3.64 ratio lsd
jonmsm
Karan, that manifold is just automotive PORN!!!!!!!
WOWZERS! Would love to see your e30 m5 (AND YOURS TOBY) some time, bet they both go like a rocket! hehe. Nothing i love more than a motorsport straight 6... Now all i need is my very own m5... Anyone wanna lend me 2k to buy the one on ebay?!?! LOL
Jon
Jon
1986 e28 M535i (gone and missed)
1988 e30 320i cab (full resto STILL in progress)
1996 Volvo 850 T-5 estate (280bhp Turbo Nutter), T-5R (my precious)
1966 Fiat 850 saloon & 1970 Sport Coupe
C1 (go-kart)
C1 (go-kart)
infusion
would the getrag 260 off my 325i mount up to a s38 b36 ?
what box do the s38 use? getrag 280 ?
Karan
no the 260 will not fit
not sure on the code of my gbox but a e30 m3 box will also fit
Andy335Touring
Karan, whats left to finish it mate ?
Karan
coolant hoses and modify bonnet to fit
cant get coolant pipes made from amywhere, there isnt enough room to join lots of samco sections up...anyone know anyone who can custom make htese?
gareth
how about rigid hoses / pipes with a short flexi rubber bit at the end??
buy a load of stainless steel tube, borrow a tig welder, a pipe bender and get playing! an excuse to learn to tig weld?
do you have any pics of the offending areas? might be worth bouncing a few ideas around?
Karan
will get some up, i toyed with this idea..... very clever and the engine is fairly solid in there so should be do-able
DieselMeister
Or try Pirtek....
Good work Karan. I look forward to seeing and hearing this in the metal.
jaistanley
Dont samco and the like make them to drawings? Knock some up in AutoCAD. You could even make simple patterns using flexi-tubing of the inner diameter you need for the hoses.
They make the pipes by forming the silicone over braid on a simple mold. Normally the mold is a piece of pipe the correct shape and slightly too long (for trimming). It's layed-up and baked to cure if I recall correctly..
Worth a phone call or two to find out?
Jai
Jai
M5pilot
What power steering pump have you used?
Karan
i have used one of an e23, with some mounting modifications
eraserr
Hello, great work Karan.
I am doing this swap myself and I am interested how long must the propshaft be for the position 3.
Thanks for help!
Thanks for help!
Karan
cars done!!
just needs pas fluid
starts doesnt overheat while standing etc and runs nice and smooth and sounds mental!!!
just drove about 50metres down the road gently
now gotta mot it
pics coming this weekend of what it looks like
oh and i had to cut a small hole in the bonnet for the plenum!!
now gotta mot it
- Homo Hair
eko
- Old timer
Weekend,fooking hell thats ages to waitKaran wrote:cars done!!
Seriously,fair play mate
