H&R roll bar problem
mine did the same fella. i used to have 17" alpina replicas. ive put 15' bbss on now and it still touches but less. if you attach the rollbar with the other holes(on the softer or harder setting) it may be more out the way.-im gonna have a look and see if that'll work today. its pretty bad design to be honest.
stuartgallafant
Demlotcrew
Theres nothing wrong with H&R bars
Andrew
Andrew
stuartgallafant
i have the standard wheels on mine and still have the above problem. i have some eccentric control arm bushes that will be going on soon so ill be able to see if they make a difference.
is your car lowered aswell mattcreak?
