M42 power?
feens
Post Sun Oct 15, 2006 8:59 pm
what engine mod's can i carry out on my 318IS? I know i can go for the Zone chip and bbtb? is there anything else i can do to up my BHP?
Thanks in advance!
Post Sun Oct 15, 2006 9:36 pm
Not a lot for little money. BMW got it mostly right in the first place.
IIRC, the standard cams can be retimed to give more peak power.
feens
Post Sun Oct 15, 2006 10:28 pm
Think cam profile isnt far away from the m3 cams! and dont know too much about the m42 engines learning a lil every day with the help of you lads here and our own irish site E30owners.com :D
Ant
Retired Team Member
Retired Team Member
Post Sun Oct 15, 2006 10:40 pm
the M42 will respond well to more advance on the inlet cam, from 100 to 106 degrees, be V careful with tweaking though, and of course, turn the engine over by hand to double check before throwing the key, I should add though, that the tweak is well known, aqnd may have already been doen, so check the current timing before making any changes
HTH
benjy
Post Sun Oct 15, 2006 11:00 pm
I was under the impression from what ive read on here that changing the cam timing can give you a bit at the top but you lose some torque lower down the revs.........or is that jut me? :?
Gaffa tape is like "the force" - it has a light side, a dark side, and it holds the universe together.
There's nothing that shouts "Poor Workmanship" more than wrinkles in the Gaffer tap
Post Sun Oct 15, 2006 11:09 pm
benjy wrote:I was under the impression from what ive read on here that changing the cam timing can give you a bit at the top but you lose some torque lower down the revs.........or is that jut me? :?
Probably so, you don't get something for nothing - and BMW designers do know what they're doing.
Ant
Retired Team Member
Retired Team Member
Post Sun Oct 15, 2006 11:12 pm
Agreed, all you can gain from tuning a peaky engine, is a peakier one dude
benjy
Post Mon Oct 16, 2006 9:57 am
Fu*k it then, supercharger it is.......... winkeye
iDreamBeemer
Post Mon Oct 16, 2006 11:03 am
Is it worth putting on a Big Bore throttle Body?
Was thinking of this plus RR retune/Zone Chip?
darren318is
Post Mon Oct 16, 2006 5:59 pm
i wanna no 2... how many horses will a zone chip and bbtb give separately and together.....?
Pal318is
Post Mon Oct 16, 2006 6:33 pm
Heater Plate from the Inlet manifold...
Pal
Pal
Image[img]http://Image
