also does ne1 know how to remove the bottom timing cover
Ideally you unbolt it whilst it's in the car......... you will need to lock up the crankshaft, and get a damn long breaker bar on there, best of luck!keggy wrote:wen im in there today ill see if theyll lend me the tools. how do u removes the bit the crank pulley bolts onto? i need to remove it to take off the bottom cover
