Meguiar's G220 V2 Dual Action Car Polisher
Mitchen
Post Sat Jan 24, 2015 2:21 pm
Anyone got this? Any experiences?
1990 320i Coupe SE
viewtopic.php?t=253048
Meatballs82
Post Sat Jan 24, 2015 2:52 pm
Used one on my sport a few times, took ages but worth it for the result.
Mitchen
Post Sat Jan 24, 2015 3:18 pm
diable wrote:What do you want to polish, a chrome dome?
The body work obviously :mad:
1990 320i Coupe SE
Kos
Post Sat Jan 24, 2015 3:43 pm
Let's get one thing clear
Paint does not and should not be attacked with a machine polisher on a regular basis. So, to buy this and then waste money on polishes and pads to then have no use for it is pointless
If you are really set on getting one, then look at the Kestral DAS 6
Mitchen
Post Sat Jan 24, 2015 3:46 pm
So how often should something like this be used? I usually polish, wax etc. once every couple of months.
1990 320i Coupe SE
Kos
Post Sat Jan 24, 2015 4:25 pm
Depends on how much lacquer you have lol
If you're looking to polish our swirls and light scratches you can probably correct 2/3 times safely before you are going to burn through the lacquer, but the chances of doing that with a DA is slim
I use a rotary and for example I've only done my touring once in 2 years. I just maintain it now. I've polished my day just once by had and then re waxed since I machined polished it. Still looks good (if I can be fucked to wash it)
If you think it will be easier to just polish your car with a normal polish like SRP and a finish pad with no cut, you'll find it's still easier and quicker to do it by hand.
I know several people who have bought DA's and have used them once, said "fuck that" and they've been sitting on a shelf collecting dust there after
Post Sat Jan 24, 2015 4:48 pm
I've got a DAS 6 and it is good.
I still think it's worth having one in the garage for the sake of £100 quid.
. If you change cars every couple of years, it's nice to give the new wagon a good going over when you buy it.
Laith
Post Tue Jan 27, 2015 9:44 pm
Ive got a G220. Its slow. Get a rotary and watch a lot of tutorials.
Anyone want mine?
RetroAde
Post Tue Jan 27, 2015 10:58 pm
Kos wrote:Let's get one thing clear
Bob on! Quite aggresive paint correction is a one off treatment if you get it right. As said, more than a couple of deep polishes and you'll begin to burn the paint. Your money's better spent on paying a pro to do it then getting into a good cleaning / waxing routine to maintain the finish.
Carmo13
Post Tue Jan 27, 2015 11:14 pm
Kos wrote:Depends on how much lacquer you have lol
If you're looking to polish our swirls and light scratches you can probably correct 2/3 times safely before you are going to burn through the lacquer, but the chances of doing that with a the is slim
I use a rotary and for example I've only done my touring once in 2 years. I just maintain it now. I've polished my day just once by had and then re waxed since I machined polished it. Still looks good (if I can be ****** to wash it)
I know several people who have bought the's and have used them once, said "**** that" and they've been sitting on a shelf collecting dust there after
He is right. I bought a rotary, used it once (did a good job mind you) now its been collecting dust for a couple of years.
jimbom30cab
Tech 1 freak
Post Tue Jan 27, 2015 11:18 pm
Nick, i've got one you can borrow if you want
Carmo13
Post Tue Jan 27, 2015 11:20 pm
Scrap that, I used it twice. Once on my car and once on my sisters when she used a scouring pad to remove tar spots, silly girl!
Gavla
Post Tue Jan 27, 2015 11:40 pm
The best results come from a rotary polisher, the safer option is a DA and as above, if you only need to get rid of light swirls then a DA will do the trick. You will need to get your pad and polish combo correct to do a proper job. The trick is then to maintain the finish. Wash with a 2 bucket method and wax as often as you can.
The cheapest alternative to getting rid of light swirl marks is to use a filler wax.
Mitchen
Post Wed Jan 28, 2015 8:17 am
jimbom30cab wrote:Nick, i've got one you can borrow if you want
Thanks Jim
I've decided to take up Gavla's services and get a proper detail done, and just maintain from there.. appreciate the offer though pal
1990 320i Coupe SE
HairyScreech
Post Wed Jan 28, 2015 11:18 am
All of the above is so true. The touring has been mopped several times in the past as it changed hands, the red is/was so thin it was getting translucent on the edges and the primer was tinting the red as you could see through it.
Too many moppings/machine polishings is why it is now just covered in base coat awaiting the better summer weather to finish a repaint.
