Meguiar's G220 V2 Dual Action Car Polisher
Mitchen
Anyone got this? Any experiences?
Meatballs82
Used one on my sport a few times, took ages but worth it for the result.
Mitchen
The body work obviouslydiable wrote:What do you want to polish, a chrome dome?
Kos
Let's get one thing clear
Paint does not and should not be attacked with a machine polisher on a regular basis. So, to buy this and then waste money on polishes and pads to then have no use for it is pointless
If you are really set on getting one, then look at the Kestral DAS 6
Mitchen
So how often should something like this be used? I usually polish, wax etc. once every couple of months.
Kos
Depends on how much lacquer you have lol
If you're looking to polish our swirls and light scratches you can probably correct 2/3 times safely before you are going to burn through the lacquer, but the chances of doing that with a DA is slim
I use a rotary and for example I've only done my touring once in 2 years. I just maintain it now. I've polished my day just once by had and then re waxed since I machined polished it. Still looks good (if I can be fucked to wash it)
If you think it will be easier to just polish your car with a normal polish like SRP and a finish pad with no cut, you'll find it's still easier and quicker to do it by hand.
I know several people who have bought DA's and have used them once, said "fuck that" and they've been sitting on a shelf collecting dust there after
I've got a DAS 6 and it is good.
I still think it's worth having one in the garage for the sake of £100 quid.
. If you change cars every couple of years, it's nice to give the new wagon a good going over when you buy it.
Laith
Ive got a G220. Its slow. Get a rotary and watch a lot of tutorials.
Anyone want mine?
Anyone want mine?
RetroAde
Bob on! Quite aggresive paint correction is a one off treatment if you get it right. As said, more than a couple of deep polishes and you'll begin to burn the paint. Your money's better spent on paying a pro to do it then getting into a good cleaning / waxing routine to maintain the finish.Kos wrote:Let's get one thing clear
Carmo13
He is right. I bought a rotary, used it once (did a good job mind you) now its been collecting dust for a couple of years.Kos wrote:Depends on how much lacquer you have lol
If you're looking to polish our swirls and light scratches you can probably correct 2/3 times safely before you are going to burn through the lacquer, but the chances of doing that with a the is slim
I use a rotary and for example I've only done my touring once in 2 years. I just maintain it now. I've polished my day just once by had and then re waxed since I machined polished it. Still looks good (if I can be ****** to wash it)
I know several people who have bought the's and have used them once, said "**** that" and they've been sitting on a shelf collecting dust there after
jimbom30cab
- Tech 1 freak
Nick, i've got one you can borrow if you want
Carmo13
Scrap that, I used it twice. Once on my car and once on my sisters when she used a scouring pad to remove tar spots, silly girl!Carmo13 wrote:He is right. I bought a rotary, used it once (did a good job mind you) now its been collecting dust for a couple of years.Kos wrote:Depends on how much lacquer you have lol
Gavla
The best results come from a rotary polisher, the safer option is a DA and as above, if you only need to get rid of light swirls then a DA will do the trick. You will need to get your pad and polish combo correct to do a proper job. The trick is then to maintain the finish. Wash with a 2 bucket method and wax as often as you can.
The cheapest alternative to getting rid of light swirl marks is to use a filler wax.
Mitchen
Thanks Jimjimbom30cab wrote:Nick, i've got one you can borrow if you want
I've decided to take up Gavla's services and get a proper detail done, and just maintain from there.. appreciate the offer though pal
HairyScreech
All of the above is so true. The touring has been mopped several times in the past as it changed hands, the red is/was so thin it was getting translucent on the edges and the primer was tinting the red as you could see through it.
Too many moppings/machine polishings is why it is now just covered in base coat awaiting the better summer weather to finish a repaint.
