overheating 320 again
zimzimzimer
Wed Jan 18, 2006 2:56 pm
my cabs overheating i thought it was the head gasket but was told to try the fan clutch by trying to stop it once warmed up so i did and it stops easly also the bottom hose is no getting warm is this normal any body got any ideas
Gwynleym10
Wed Jan 18, 2006 3:15 pm
When is it overheating?
All the time, heats up very quickly
In traffic, but goes down when you get your speed up?
London 2 Cape Town
www.Overlandinthesun.com
zimzimzimer
Wed Jan 18, 2006 3:20 pm
if i start it up and leave to idle it takes about 5 mins,if i drive it take about 2 mins
kam-325i
Wed Jan 18, 2006 3:21 pm
Headgasket anyone ?
zimzimzimer
Wed Jan 18, 2006 3:22 pm
these no water in the oil
Wed Jan 18, 2006 3:25 pm
sounds like a thermostat problem if the bottom hose is not getting warm. Thermostat is Ԛ£24 from the stealers, less from GSF. But the fan viscous clutch sounds like it could be dodgy too if it is easily stopped when the vehicle is warm. I would investigate these items further. If it is warming up very quickly I would avoid using the car as you may end up with a cracked head if you let it cook.
gcorky
Boost Junkie
Wed Jan 18, 2006 5:43 pm
zimzimzimer wrote:these no water in the oil
dont need water in oil for h/g failure ,could be exhausting in to cooling system.
try stat and viscous first cos you need them.
any pressure in expansion tank?????
525 sport
johnnyboy
Thu Jan 19, 2006 10:29 pm
Also it could be a knackered radiator. I don't think you can back flush e30 rads though can you???
I would try thermostat first.
cheers,
john
