overheating 320 again
zimzimzimer
Post Wed Jan 18, 2006 2:56 pm
my cabs overheating i thought it was the head gasket but was told to try the fan clutch by trying to stop it once warmed up so i did and it stops easly also the bottom hose is no getting warm is this normal any body got any ideas
Gwynleym10
Post Wed Jan 18, 2006 3:15 pm
When is it overheating?
All the time, heats up very quickly
In traffic, but goes down when you get your speed up?
London 2 Cape Town
www.Overlandinthesun.com
zimzimzimer
Post Wed Jan 18, 2006 3:20 pm
if i start it up and leave to idle it takes about 5 mins,if i drive it take about 2 mins
kam-325i
Post Wed Jan 18, 2006 3:21 pm
Headgasket anyone ?
zimzimzimer
Post Wed Jan 18, 2006 3:22 pm
these no water in the oil
Post Wed Jan 18, 2006 3:25 pm
sounds like a thermostat problem if the bottom hose is not getting warm. Thermostat is Ԛ£24 from the stealers, less from GSF. But the fan viscous clutch sounds like it could be dodgy too if it is easily stopped when the vehicle is warm. I would investigate these items further. If it is warming up very quickly I would avoid using the car as you may end up with a cracked head if you let it cook.
gcorky
Boost Junkie
Post Wed Jan 18, 2006 5:43 pm
zimzimzimer wrote:these no water in the oil
dont need water in oil for h/g failure ,could be exhausting in to cooling system.
try stat and viscous first cos you need them.
any pressure in expansion tank?????
525 sport
johnnyboy
Post Thu Jan 19, 2006 10:29 pm
Also it could be a knackered radiator. I don't think you can back flush e30 rads though can you???
I would try thermostat first.
cheers,
john
