My new 316!
Junglistjed
What would you recommend doing mate? i want my new HU in on tuesday so trying to order everything i need now!
You could use a multimeter, or test lamp to verify the power connections in that terminal block, and add in-line fuses as required, then add the adaptor loom to it.
Testing the speakers is a case of briefly connecting a small 1.5V watch battery across the pair of wires (e.g., the pair of blue ones then the pair of yellow ones) and listening for the click as the speaker sounds - that will also identify which speaker is which.
Junglistjed
what adapter loom?Speedtouch wrote:You could use a multimeter, or test lamp to verify the power connections in that terminal block, and add in-line fuses as required, then add the adaptor loom to it.
Junglistjed
one of these mate?DaveyB wrote:get a standard iso female and solder it in, just gotta play chase the wires
http://www.ebay.co.uk/itm/16-Pin-Female ... 3ccb41c0c9
Junglistjed
noticed some rust bubbles when i cleaner the car today, shall i get them sorted asap?
Junglistjed
can someone link me to the connector i need to sort the wiring out? doubt it will come on tuesday but atleast ill have it for the weekend
rust doesn't get better with age, so yes, sooner rather than later is preferable.
are you ignoring my PM for some reason Jedd?
[quote="bss325i"]
Junglistjed
I may have deleted it? resend it adi
ok. it's still in my outbox, that's all. something you asked me about.
i'll resend it Jedd
i'll resend it Jedd
[quote="bss325i"]
Junglistjed
Car is back at the garage getting its finishing touches, i know there is a lot of fabricators etc on here and im wondering if anyone could give me an estimate for dent removal and repsray of a front arch?
Junglistjed
Need some advise lads, do i change the exhaust or keep it standard? i would like something that 'prettier' that sounds nicer but then again i don't want the car turning into a chav mobile..
Junglistjed
Car is back
for those interested it turns out the carb is missing something, acceleration idle piston or something? lad said the best thing to do is next time its giving me trouble i should replace it with a weber
Next on the cards is a nice set of creme leathers to match the doorcards!
That'll probably be a split diaphragm on the accelerator pump jet circuit.
I notice your post count is now 316!
Junglistjed
rev counter hasn't been working for a while and now thermostat isn't working.. any ideas?
Rev counter could be a bad earth to the gauge, or not getting the required input signal from the switched side of the ignition coil, so check those connections.
Thermostat not working - try removing it and dunking it in a Pyrex jug of boiling water. if it doesn't open, then you need a new one.
Junglistjed
ok well now the speedo has stopped working...
Check the sensor and the wiring to it on the back axle.
Junglistjed
whay coul be wrong with it?
Anything, given the dousing of road spray it gets on a regular basis.
- hillbilly30
When you say thermostat, do you mean temp gauge? Just that if the speedo, rev counter and temp gauge are dead then it's a different issue. Just want to clarify as thermostat seems an odd coinsidense with a dead rev and mph dial
Junglistjed
Yeah i meant temp gauge sorry, the rev counter hasn't worked for a while, the temp gauge worked in the morning yesterday, but not in the afternoon, exact same today.. and speedo stopped working today.. so basically all 3 have stopped :/
I was sorting out the wiring for a headunit if i could of blown something?
- Brianmoooore
Tacho. and temp gauge will most likely be failed SI board batteries, and the speedo. could well be a blown fuse (10, 12 or 21) if you've been playing with the wiring.
Junglistjed
Will check the fuse box tomorrow (where is it?) , definitely need to sort the speedo!
cheers guys
cheers guys
Fuse box is right behind the nearside front suspension turret.
http://www.e30zone.net/e30zonewiki/index.php/Fuse_Box
Junglistjed
Will have a look tomorrow thanks mate, need to stock up on fuses anyway so a trip to halfords is in order.
Junglistjed
checked the fuse box and 21 is definitely blown which could be the reason i cant get the radio to turn on! but how do i check the other fuses? (they are older ones and not see through)
You can usually tell just by looking at them - blown ones often have tell-tale burnt bits! However, they can also be tested with a multimeter set to ohms or continuity range, or rig up a test lamp circuit using a bulb or LED in series with a battery of suitable voltage.
Junglistjed
cheers bud
would 21 be causing the speedo to not work?
No, fuse 12 feeds the power to the speedo.
Junglistjed
i will replace that one too and see what happens then bud
Junglistjed
Junglistjed
Out of curiosity, how easy is an engine swap in a 316 and how much on average would it cost me?
Zone Wiki is your friend:
http://www.e30zone.net/e30zonewiki/inde ... gine_Swaps
Cost very much dependent on which engine you go for and who you get to fit it, and how many other upgrades you need to make, e.g., brakes, suspension, etc.!
Junglistjed
for anyone who has fitted front component speakers, where did you place the crossovers?
