My new 316!
Junglistjed
Post Sat Oct 12, 2013 11:52 pm
What would you recommend doing mate? i want my new HU in on tuesday so trying to order everything i need now!
Post Sun Oct 13, 2013 12:07 am
You could use a multimeter, or test lamp to verify the power connections in that terminal block, and add in-line fuses as required, then add the adaptor loom to it.
Testing the speakers is a case of briefly connecting a small 1.5V watch battery across the pair of wires (e.g., the pair of blue ones then the pair of yellow ones) and listening for the click as the speaker sounds - that will also identify which speaker is which.
DaveyB
Post Sun Oct 13, 2013 12:08 am
get a standard iso female and solder it in, just gotta play chase the wires
Wanted Nothing atm :)!
Junglistjed
Post Sun Oct 13, 2013 12:16 am
Speedtouch wrote:You could use a multimeter, or test lamp to verify the power connections in that terminal block, and add in-line fuses as required, then add the adaptor loom to it.
what adapter loom?
Junglistjed
DaveyB wrote:get a standard iso female and solder it in, just gotta play chase the wires
one of these mate?
http://www.ebay.co.uk/itm/16-Pin-Female ... 3ccb41c0c9
Junglistjed
Post Sun Oct 13, 2013 4:40 pm
noticed some rust bubbles when i cleaner the car today, shall i get them sorted asap?
Junglistjed
Post Sun Oct 13, 2013 5:10 pm
can someone link me to the connector i need to sort the wiring out? doubt it will come on tuesday but atleast ill have it for the weekend :)
adit
Post Sun Oct 13, 2013 5:35 pm
rust doesn't get better with age, so yes, sooner rather than later is preferable.
are you ignoring my PM for some reason Jedd? :?
[quote="bss325i"]
Junglistjed
Post Sun Oct 13, 2013 5:38 pm
I may have deleted it? resend it adi :)
adit
Post Sun Oct 13, 2013 7:12 pm
ok. it's still in my outbox, that's all. something you asked me about.
i'll resend it Jedd
[quote="bss325i"]
Junglistjed
Post Mon Oct 14, 2013 3:42 pm
Car is back at the garage getting its finishing touches, i know there is a lot of fabricators etc on here and im wondering if anyone could give me an estimate for dent removal and repsray of a front arch?
Junglistjed
Post Mon Oct 14, 2013 11:12 pm
Need some advise lads, do i change the exhaust or keep it standard? i would like something that 'prettier' that sounds nicer but then again i don't want the car turning into a chav mobile..
Junglistjed
Post Tue Oct 15, 2013 6:32 pm
Car is back :D for those interested it turns out the carb is missing something, acceleration idle piston or something? lad said the best thing to do is next time its giving me trouble i should replace it with a weber :)
Next on the cards is a nice set of creme leathers to match the doorcards!
Post Tue Oct 15, 2013 11:08 pm
That'll probably be a split diaphragm on the accelerator pump jet circuit.
I notice your post count is now 316! :)
Junglistjed
Post Thu Oct 17, 2013 5:36 pm
rev counter hasn't been working for a while and now thermostat isn't working.. any ideas?
Post Thu Oct 17, 2013 5:51 pm
Rev counter could be a bad earth to the gauge, or not getting the required input signal from the switched side of the ignition coil, so check those connections.
Thermostat not working - try removing it and dunking it in a Pyrex jug of boiling water. if it doesn't open, then you need a new one.
Junglistjed
Post Fri Oct 18, 2013 3:44 pm
ok well now the speedo has stopped working...
Post Fri Oct 18, 2013 4:01 pm
Check the sensor and the wiring to it on the back axle.
Junglistjed
Post Fri Oct 18, 2013 7:44 pm
whay coul be wrong with it?
Post Fri Oct 18, 2013 10:24 pm
Anything, given the dousing of road spray it gets on a regular basis.
hillbilly30
Post Fri Oct 18, 2013 10:39 pm
When you say thermostat, do you mean temp gauge? Just that if the speedo, rev counter and temp gauge are dead then it's a different issue. Just want to clarify as thermostat seems an odd coinsidense with a dead rev and mph dial
Junglistjed
Post Fri Oct 18, 2013 11:02 pm
Yeah i meant temp gauge sorry, the rev counter hasn't worked for a while, the temp gauge worked in the morning yesterday, but not in the afternoon, exact same today.. and speedo stopped working today.. so basically all 3 have stopped :/
I was sorting out the wiring for a headunit if i could of blown something?
Post Fri Oct 18, 2013 11:48 pm
Tacho. and temp gauge will most likely be failed SI board batteries, and the speedo. could well be a blown fuse (10, 12 or 21) if you've been playing with the wiring.
Junglistjed
Post Sat Oct 19, 2013 12:03 am
Will check the fuse box tomorrow (where is it?) , definitely need to sort the speedo!
cheers guys
Post Sat Oct 19, 2013 12:06 am
Fuse box is right behind the nearside front suspension turret.
http://www.e30zone.net/e30zonewiki/index.php/Fuse_Box
Junglistjed
Post Sat Oct 19, 2013 12:10 am
Will have a look tomorrow thanks mate, need to stock up on fuses anyway so a trip to halfords is in order.
Junglistjed
Post Sat Oct 19, 2013 10:31 pm
checked the fuse box and 21 is definitely blown which could be the reason i cant get the radio to turn on! but how do i check the other fuses? (they are older ones and not see through)
Post Sat Oct 19, 2013 11:01 pm
You can usually tell just by looking at them - blown ones often have tell-tale burnt bits! However, they can also be tested with a multimeter set to ohms or continuity range, or rig up a test lamp circuit using a bulb or LED in series with a battery of suitable voltage.
Junglistjed
Post Sat Oct 19, 2013 11:11 pm
cheers bud :) would 21 be causing the speedo to not work?
Post Sat Oct 19, 2013 11:15 pm
No, fuse 12 feeds the power to the speedo.
Junglistjed
Post Sat Oct 19, 2013 11:18 pm
i will replace that one too and see what happens then bud
Junglistjed
Post Mon Oct 21, 2013 5:27 pm
speedo is sorted and the headunit turns on! only problem is no speakers and no aerial :( any ideas?
Junglistjed
Post Tue Oct 22, 2013 6:03 pm
Out of curiosity, how easy is an engine swap in a 316 and how much on average would it cost me?
Post Tue Oct 22, 2013 6:25 pm
Zone Wiki is your friend:
http://www.e30zone.net/e30zonewiki/inde ... gine_Swaps
Cost very much dependent on which engine you go for and who you get to fit it, and how many other upgrades you need to make, e.g., brakes, suspension, etc.!
Junglistjed
Post Sun Oct 27, 2013 10:28 pm
for anyone who has fitted front component speakers, where did you place the crossovers?
