M52 b30 stroker rebuild back on the road
Tue Jul 23, 2013 3:51 pm
Fair enough, squire! :o:
leeparkes
Tue Jul 23, 2013 4:18 pm
If its possible (ie valve to piston clearance) id use a standard gasket, it will raise the compression which is never a bad thing. 8)
Tue Jul 23, 2013 4:47 pm
Except, perhaps, on a turbo engine conversion that has already caused enough agg! :wink:
harry_p
Tue Jul 23, 2013 7:54 pm
I agree with lee, as standard theyre built with a compression ratio which will withstand all sorts of crappy fuel. Upping the compression ratio a little won't do any harm on the decent quality fuel we get.
A lot of heads have a cast in mark to show when theyve reached the skimming limit, do m52 heads have anything similar?
the m52b28 compression ratio is only 10.2:1 as standard, an e36 m3 is 11.3:1
cheers,
harry
Tue Jul 23, 2013 8:32 pm
i don't know if the heads been skimmed or not before and with the amount taken off this time i'm playing it safe with the thicker gasket .
Tue Jul 23, 2013 9:25 pm
12 thou is more than the difference between standard and oversized gasket
Id be rocking the standard though, you would be somewhere about 10.8:1 8)
Tue Jul 23, 2013 9:37 pm
so i'll still be above normal compression with the thicker one but compression would be increased further by using the standard one .
all this has got my head done in :mad:
gooner1
Out humping Reindeer
Tue Jul 23, 2013 9:41 pm
magpie wrote:so i'll still be above normal compression with the thicker one but compression would be increased further by using the standard one .
You need it pressure tested, Mick. :wink:
Neilios
Tue Jul 23, 2013 9:42 pm
DanThe wrote:12 thou is more than the difference between standard and oversized gasket
So would I with only 0.3mm skimmed off.
maggspower
Turbo Farmer Tractor Driver
Tue Jul 23, 2013 9:56 pm
Standard gasket is 1.75mm
The thick one is 2.05mm
Thats 0.3 thicker.
12 thou, or 0.012" is 0.3048mm, or as near as makes no difference 0.3mm.
I would be banging a standard gasket back in there, just my opinion though.
Wed Jul 24, 2013 9:46 am
magpie wrote:i don't know if the heads been skimmed or not before and with the amount taken off this time i'm playing it safe with the thicker gasket .
Even if there's no dimples in the head face, you can measure the total thickness of the head from face to cam cover to see the total that's been taken off from stock.
I don't have the figure for a standard M52 head, but I'm sure someone on here can come up with it.
Fri Jul 26, 2013 2:01 pm
the head gasket and bolts are en route today , the block face and bolt holes have been thoroughly cleaned ............fingers crossed i guess
BMW_E30vert
Fri Jul 26, 2013 2:48 pm
Good luck mate patiently watching :thumb:
Fri Jul 26, 2013 5:49 pm
x2 bolts stripped the block threads on the last turn ...........who never had their fingers crossed,c'mon own up!
Fri Jul 26, 2013 8:54 pm
heli coil kit ordered .
http://www.ebay.co.uk/itm/390603217799? ... 1439.l2649
and longer coils needed.
http://www.ebay.co.uk/itm/310392311016? ... 1439.l2649
bit nervous about this bit :mad:
maggspower
Fri Jul 26, 2013 9:15 pm
Dont worry about it, just take your time :D
The drill needs to go down the original hole square, following its line.
When you tap the threads, lube it up, and make sure you start the threads square. You will need to blow it out with air afterwards. Don't be affraid to run the tap down twice, but do get it clean. Lube the helicoil before it goes in with light oil, and check its clean.
Any crap or swarf will send the helicoil down on the wonk, so get it clean. Sorry for repeating myself :D
Fri Jul 26, 2013 10:02 pm
maggspower wrote:Dont worry about it, just take your time :D
don't worry about repeating yourself Byron,think i'll have a practise on the blown block i've got waiting for the bridge...
i hate doing important things i've never done before ,but afterwards you look back and say piece of p1ss that ....I just need a tin of confidence boost lol
leeparkes
Sat Jul 27, 2013 10:08 am
Unlucky mate. :(
Sun Aug 04, 2013 5:42 pm
some e30 lovin truly went on today,Neilios [captain confident] popped over and sorted the heli coils out in his stride and out of the blue Craig arrived and torqued the head up,put the cams in/vanos etc a timed it up .
get stuck in Neil :)
and after my other best friend of the week had finished his magic ..
i'll be boxing it all up sometime tomorrow weather depending and we try again .
Sun Aug 04, 2013 11:28 pm
Nice to see some grafters dropping in to get you going Mick winkeye
Not long now :cool:
Wed Aug 07, 2013 3:30 pm
it's not looking good,i'm only running on 5 cylinders :cry:
i started this in the tech help section.....
http://www.e30zone.net/modules.php?name ... 86#2643886
if anyone can give any ideas of WTF to do next i'm all ears and very p1ssed off !
Sat Aug 10, 2013 5:36 pm
more money wasted....taken from the link in the tech help section .
the results are in...
pot 1
pot 2
pot 3
pot 4
pot 5
and finally pot 6
:( engine number two F00ked !
Andeep
Sat Aug 10, 2013 7:20 pm
Sat Aug 10, 2013 8:16 pm
Motherfocker.
What a load of cooonting about.
Feel for you mate :(
leeparkes
Sat Aug 10, 2013 8:25 pm
That's proper fooked with only about 30psi 8O
Sat Aug 10, 2013 9:08 pm
Bent valves? Wonder whats happened there :?
Sat Aug 10, 2013 9:19 pm
if i looked into another donk and bought a manual R-P reg e34 could i use the gearbox ?
not sure what it is yet but i think it's bent valves on pot 6 as there is a clank noise coming from there .
[youtube][/youtube]
that noise is from pot 6 ,half way through cranking when restarting it it seemed like the whole engine seized and tried to crank itself out of the bay so i let go of they key,gave it few secs then it started :?
rich318i
Sat Aug 10, 2013 9:20 pm
block threads have been pulled when pulling the head down. do a sniff test.
Sat Aug 10, 2013 9:23 pm
it's been heli coiled and torqued up
rich318i
Sat Aug 10, 2013 9:24 pm
cool
Sat Aug 10, 2013 10:04 pm
Did you get round to taking the cover off to check timing Mick?
Sat Aug 10, 2013 10:12 pm
not yet mate ,gonna have a look tomorrow .
rich318i
Sat Aug 10, 2013 11:28 pm
timing sounds way off, jumped about three teeth. but the compression test would have shown that wouldnt it all pots ? not just one being low as its two pistons per bang.
the block got the steel liners?
Sat Aug 10, 2013 11:53 pm
yep steel liners
Thu Aug 15, 2013 10:35 am
we've identified the problem and it's the valves on pot 6 . the head is coming off tomorrow and replace all the valves on pot 6 then put back together using a new gasket but this time it's going to be the standard one to pinch an odd bhp or two + it's half the price of the thicker one .
Tech help section FTW! :group:
