M52 b30 stroker rebuild back on the road
Fair enough, squire!
leeparkes
If its possible (ie valve to piston clearance) id use a standard gasket, it will raise the compression which is never a bad thing.
Except, perhaps, on a turbo engine conversion that has already caused enough agg!
harry_p
I agree with lee, as standard theyre built with a compression ratio which will withstand all sorts of crappy fuel. Upping the compression ratio a little won't do any harm on the decent quality fuel we get.
A lot of heads have a cast in mark to show when theyve reached the skimming limit, do m52 heads have anything similar?
the m52b28 compression ratio is only 10.2:1 as standard, an e36 m3 is 11.3:1
cheers,
harry
harry
i don't know if the heads been skimmed or not before and with the amount taken off this time i'm playing it safe with the thicker gasket .
+ a yard full of scrap turds
12 thou is more than the difference between standard and oversized gasket
Id be rocking the standard though, you would be somewhere about 10.8:1
so i'll still be above normal compression with the thicker one but compression would be increased further by using the standard one .
all this has got my head done in
gooner1
- Out humping Reindeer
You need it pressure tested, Mick.magpie wrote:so i'll still be above normal compression with the thicker one but compression would be increased further by using the standard one .
Neilios
So would I with only 0.3mm skimmed off.DanThe wrote:12 thou is more than the difference between standard and oversized gasket
maggspower
- Turbo Farmer Tractor Driver
Standard gasket is 1.75mm
The thick one is 2.05mm
Thats 0.3 thicker.
12 thou, or 0.012" is 0.3048mm, or as near as makes no difference 0.3mm.
I would be banging a standard gasket back in there, just my opinion though.
Thats 0.3 thicker.
Contact: theengineshedonline@gmail.com
Even if there's no dimples in the head face, you can measure the total thickness of the head from face to cam cover to see the total that's been taken off from stock.magpie wrote:i don't know if the heads been skimmed or not before and with the amount taken off this time i'm playing it safe with the thicker gasket .
I don't have the figure for a standard M52 head, but I'm sure someone on here can come up with it.
the head gasket and bolts are en route today , the block face and bolt holes have been thoroughly cleaned ............fingers crossed i guess
BMW_E30vert
Good luck mate patiently watching
x2 bolts stripped the block threads on the last turn ...........who never had their fingers crossed,c'mon own up!
heli coil kit ordered .
http://www.ebay.co.uk/itm/390603217799? ... 1439.l2649
and longer coils needed.
http://www.ebay.co.uk/itm/310392311016? ... 1439.l2649
bit nervous about this bit
maggspower
Dont worry about it, just take your time
The drill needs to go down the original hole square, following its line.
When you tap the threads, lube it up, and make sure you start the threads square. You will need to blow it out with air afterwards. Don't be affraid to run the tap down twice, but do get it clean. Lube the helicoil before it goes in with light oil, and check its clean.
Any crap or swarf will send the helicoil down on the wonk, so get it clean. Sorry for repeating myself
don't worry about repeating yourself Byron,think i'll have a practise on the blown block i've got waiting for the bridge...maggspower wrote:Dont worry about it, just take your time![]()
i hate doing important things i've never done before ,but afterwards you look back and say piece of p1ss that ....I just need a tin of confidence boost lol
leeparkes
Unlucky mate.
some e30 lovin truly went on today,Neilios [captain confident] popped over and sorted the heli coils out in his stride and out of the blue Craig arrived and torqued the head up,put the cams in/vanos etc a timed it up .
get stuck in Neil
and after my other best friend of the week had finished his magic ..
i'll be boxing it all up sometime tomorrow weather depending and we try again .
get stuck in Neil
Nice to see some grafters dropping in to get you going Mick
Not long now
Not long now
it's not looking good,i'm only running on 5 cylinders
i started this in the tech help section.....
http://www.e30zone.net/modules.php?name ... 86#2643886
if anyone can give any ideas of WTF to do next i'm all ears and very p1ssed off !
more money wasted....taken from the link in the tech help section .
the results are in...
pot 1
pot 2
pot 3
pot 4
pot 5
and finally pot 6
engine number two F00ked !
pot 1
pot 2
pot 3
pot 4
pot 5
and finally pot 6
Motherfocker.
What a load of cooonting about.
Feel for you mate
Feel for you mate
leeparkes
That's proper fooked with only about 30psi
Bent valves? Wonder whats happened there
if i looked into another donk and bought a manual R-P reg e34 could i use the gearbox ?
not sure what it is yet but i think it's bent valves on pot 6 as there is a clank noise coming from there .
[youtube][/youtube]
that noise is from pot 6 ,half way through cranking when restarting it it seemed like the whole engine seized and tried to crank itself out of the bay so i let go of they key,gave it few secs then it started
[youtube][/youtube]
rich318i
block threads have been pulled when pulling the head down. do a sniff test.
it's been heli coiled and torqued up
rich318i
cool
Did you get round to taking the cover off to check timing Mick?
not yet mate ,gonna have a look tomorrow .
rich318i
timing sounds way off, jumped about three teeth. but the compression test would have shown that wouldnt it all pots ? not just one being low as its two pistons per bang.
the block got the steel liners?
yep steel liners
we've identified the problem and it's the valves on pot 6 . the head is coming off tomorrow and replace all the valves on pot 6 then put back together using a new gasket but this time it's going to be the standard one to pinch an odd bhp or two + it's half the price of the thicker one .
Tech help section FTW!
