Goosie's S50 Moredoor, 'Ring action
Greeny
Post Thu Apr 18, 2013 7:44 pm
Seam sealer and underseal cover a multitude of sins! I swear by the stuff. :D
Gone but not forgotten.
('92 325i Cabriolet)
goosiegander
Zonegoose
Post Thu Apr 18, 2013 11:13 pm
All done,
Wing on, sills and rear arch treated for surface scabbing and touched in, and now back on the deck for the first time in weeks
Fook am i tired of it now... :)
goosiegander
Zonegoose
Post Fri Apr 19, 2013 5:57 pm
Fresh ticket and minus a set of tyres ready for the Nurburgring next weekend
Tan91
Post Fri Apr 19, 2013 6:05 pm
Could I ask what welder did you get..
Gas or Gasless?
Make and Model if available?
Because I am planning on buying one to do the same this summer, Looking at the Clarke Gasless MIG 145,
Any help greatly appreciated as, being able to weld good eventually is a very good skill to have, looking good for a first time touching a welder LOL, but hey ho you will get better like you've said.
Tan.
1990 - 316i LUX Coupe[/size:364a72de04]
goosiegander
Zonegoose
Post Fri Apr 19, 2013 6:33 pm
Its a clarke welder dude, i'll get you the spec later this evening,
Using 100% co2 gas but will switch to Argon/co2 mix when this bottle runs out 0.6mm wire and 0.9mm steal sheets
If i'd had more metal working tools perhaps i could have made a slightly better finish but i'm happy for now
Tan91
Post Fri Apr 19, 2013 6:38 pm
goosiegander wrote:Its a clarke welder dude, i'll get you the spec later this evening,
Yeah that's expected anyway, look at it this way, you have no rust, regardless of appearance. Just wondering if bonnet skin could be used or wing skin as I have some laying around, because I will be doing those exact areas on both sides.
Don't worry take your time dude!
tomislav
Post Fri Apr 19, 2013 7:12 pm
Off to the ring eh? When you going?
There's a load of us going out for the 24 hour race 15th to 21st may then back again to track the new 325 1st to 5th august
goosiegander
Zonegoose
Post Fri Apr 19, 2013 8:52 pm
tomislav wrote:Off to the ring eh? When you going?
Heading over on saturday next and returning on the monday so evening and full day on the circuit with at least one evening meal at the pistonklause,
Defo up for going over in august hopefully that will have been enough time to sort the sport out for some light track work
hennared323i
Post Fri Apr 19, 2013 10:34 pm
Tanveer wrote:Yeah that's expected anyway, look at it this way, you have no rust, regardless of appearance. Just wondering if bonnet skin could be used
Brianmooooooooore admitted a few years ago that he uses E34 bonnets for repair patches.
Respect Goosiegander
Tan91
Post Sat Apr 20, 2013 12:29 am
What do you mean by 'admitting', is it a bad thing, metal too thin?
hennared323i
Post Sat Apr 20, 2013 7:27 am
Nope, it is the mooooooooore we are talking about, bonnets are ideal
goosiegander
Zonegoose
Post Sat Apr 20, 2013 9:11 am
http://www.ebay.co.uk/itm/180654184762? ... 1497.l2649
Theres some steal, same thickness that i used,
Thanks guys BTW :)
goosiegander
Zonegoose
Post Sun Apr 21, 2013 6:54 pm
Tanveer wrote:Could I ask what welder did you get..
Gas or Gasless?
Tan.
Clarke 120E Dude :)
Well, following the welding and other council activity visited on the moordoor turd today was set aside for sorting out the replacement wing which was rust free but had seen some sponge and fairy liquid action in its past;
Especially here,
and here
...to be continued
goosiegander
Zonegoose
Post Sun Apr 21, 2013 7:10 pm
So wet-sanding isn't everyone's cup of tea given how poorly it can turn out, as in 'i went through to the primer and am going to be poor having to pay for paint...'
But with a little practice,
Now when Dan polished the car previously it was done with PF2500 which can be used as a bit of a 'one trick pony' good overall result and skips the heavy cut and refinement either side of it...
That being the case sections of the car have been redone with other bits still to do, anyway 50/50's are gay so,
Wax on,
...and wax off
Shiny!
Tan91
Post Sun Apr 21, 2013 7:43 pm
So did you wet sand the wing then went over with pf2500? came out pretty decent, I sprayed my front wings first time and got some orange peel in certain areas need to correct to it look better.
goosiegander
Zonegoose
Post Sun Apr 21, 2013 8:05 pm
Tanveer wrote:So did you wet sand the wing then went over with pf2500? came out pretty decent, I sprayed my front wings first time and got some orange peel in certain areas need to correct to it look better.
Clay
Wetsand
Fast Gloss Heavy cut x2
Power finish Med cut
Final finish Light cut
Glaze and wax
I could have taken it a hell of a lot further but to be honest as most of the rest of the car needs going over again i was happy with that...
PF2500 by itself will not be man enough to get rid of wet-sanding marks unless you want to do 20 passes with it...
scott180gtb
Post Sun Apr 21, 2013 8:15 pm
Shiny :cool: :cool:
Cars
2007 VW Caravelle 2.5 TDI 250 bhp 550 NM
1989 325i Sport Gone :(
2003 E46 320d Touring
1998 E36 M3 EVO Track Toy
1996 E36 328i Sport welder-up project
goosiegander
Zonegoose
Post Mon Apr 22, 2013 8:35 am
scott180gtb wrote:Shiny :cool: :cool:
Thank you sir! :D
toby
Post Mon Apr 22, 2013 6:34 pm
That's great stuff! Did you use the Menzerna gear?
Post Mon Apr 22, 2013 6:44 pm
~BUMBACLAAT! :cool:
goosiegander
Zonegoose
Post Mon Apr 22, 2013 7:46 pm
toby wrote:That's great stuff! Did you use the Menzerna gear?
For the polishing stages yes,
Mainly CG products from there on in,
goosiegander
Zonegoose
Post Mon Apr 22, 2013 7:47 pm
Rav335uk wrote:~BUMBACLAAT! :cool:
LOL!
Whens the cab coming out for a clean Rav? :D
Post Wed Apr 24, 2013 8:56 am
It's now Insured, so hopefully when the chromie goes off to have some minor welding to be done, i'll have space on the front to get the cab on. :D
goosiegander
Zonegoose
Post Thu May 02, 2013 7:09 pm
Well an evening and a day on the Nurburgring:
Car performed well and was an awesome holiday :D
Jonas
Post Thu May 02, 2013 7:11 pm
Looks awesome stuff :)!
maxfield
Post Thu May 02, 2013 7:15 pm
tomislav
Post Fri May 03, 2013 10:15 am
So exectly how much did you enjoy yourself out there eh? Fun isnt it?
E30Kop
Post Fri May 03, 2013 3:01 pm
WOW I just went through your entire thread...hats off to you for keeping you hand on this one hey.
My ultimate dream is an S50/S54 in an E30
Mmmmmm maybe I should liberate my S50B32 from my MoreDoor winkeye
goosiegander
Zonegoose
Post Fri May 03, 2013 8:55 pm
Thanks Guys! :D
Yes awesome experience though i still have much to learn!
Really have an itch to build an S54 track car now with M3 pannels...
tomislav
Post Sun May 05, 2013 11:19 am
Time to get some deep pockets!
goosiegander
Zonegoose
Post Sun May 19, 2013 9:08 pm
Some random pics:
Post Sun May 19, 2013 9:10 pm
New camera good then :mad:
Tan91
Post Sun May 19, 2013 9:29 pm
This is Bad-Ass the banked picture looks amazing
What sort of speeds you get up to on the straights??
Jamie8GTi
Post Thu Aug 01, 2013 12:55 pm
Love this car mate! looks spot on
goosiegander
Zonegoose
Post Fri Aug 02, 2013 3:39 pm
Thanks guys, only clipped a ton a couple of times, was more concerned about coming home with the car in one piece
