leaking some where :(
mucka88
hiya, only brought my new e30 about 2 months ago, and now have noticed, water collecting the battery tray, and also in the footwells carpets am soaked, is this a common problem, i have the 1.8 4door with sunroof, so maybe thinking this could be a cause with drainage, not sure.... can anyone help? thanks
askjeevesplease
Its a common problem im afraid.
Tech1 Sport, 318is, Rare Escort 1.3 RS turbo, Rust perventing BShitter.
BATTS91
check the wiki out sir theres something on the about it im sure i see the other day , could be blocked drainage or your bonnet out of alignment causing water to run off in wrong direction
G-Bear
If you've got wet footwells, might be good to have a read through this in the wiki pages too..
http://www.e30zone.net/e30zonewiki/index.php/Rust
Rich320I
Wet foot wells could mean perhaps a hole/rust issue with the bulk head area, or the front wheel arches are holed and water is coming up as your driving along. the sunroof drains to the rear/boot of the car so don’t think that would be the cause of the problem.
mucka88
thanks for the comments guys, hoping to get over a pit the week end to check for rust and holes, checked out the wiki, and thumbs up to that
Rust
goosiegander
- Zonegoose
ut-ho! doesn't sound good!
On a positive note , wet carpet =more weight !mucka88 wrote:hiya, only brought my new e30 about 2 months ago, and now have noticed, water collecting the battery tray, and also in the footwells carpets am soaked, is this a common problem, i have the 1.8 4door with sunroof, so maybe thinking this could be a cause with drainage, not sure.... can anyone help? thanks
rich318i
if there soaked thats really not good about £500 worth of welding at least
Fixedrich318i wrote:if they're soaked that's really good , about £200 worth on the bridge at least
goosiegander
- Zonegoose
and i thought you ment downforce Peter LOL!pacerpete wrote:On a positive note , wet carpet =more weight !mucka88 wrote:hiya, only brought my new e30 about 2 months ago, and now have noticed, water collecting the battery tray, and also in the footwells carpets am soaked, is this a common problem, i have the 1.8 4door with sunroof, so maybe thinking this could be a cause with drainage, not sure.... can anyone help? thanks
zaust
- Zone day release
Really ?goosiegander wrote:and i thought you ment downforce Peter LOL!pacerpete wrote:On a positive note , wet carpet =more weight !mucka88 wrote:hiya, only brought my new e30 about 2 months ago, and now have noticed, water collecting the battery tray, and also in the footwells carpets am soaked, is this a common problem, i have the 1.8 4door with sunroof, so maybe thinking this could be a cause with drainage, not sure.... can anyone help? thanks
goosiegander
- Zonegoose
Downforce in a moordoor essential...
mucka88
Right sorted problem I hope, after stripping interior it was the footwell bungs, they come out of place so put back in sealed, but drivers side jacking point was slighty cracked so welded. So all is dry again now . Thank you for the suggestions guys
