leaking some where :(
mucka88
Post Sun Apr 22, 2012 11:26 pm
hiya, only brought my new e30 about 2 months ago, and now have noticed, water collecting the battery tray, and also in the footwells carpets am soaked, is this a common problem, i have the 1.8 4door with sunroof, so maybe thinking this could be a cause with drainage, not sure.... can anyone help? thanks
askjeevesplease
Post Mon Apr 23, 2012 1:46 am
Its a common problem im afraid.
Tech1 Sport, 318is, Rare Escort 1.3 RS turbo, Rust perventing BShitter.
BATTS91
Post Mon Apr 23, 2012 3:38 am
check the wiki out sir theres something on the about it im sure i see the other day , could be blocked drainage or your bonnet out of alignment causing water to run off in wrong direction
G-Bear
Post Mon Apr 23, 2012 1:35 pm
If you've got wet footwells, might be good to have a read through this in the wiki pages too..
http://www.e30zone.net/e30zonewiki/index.php/Rust
Rich320I
Post Mon Apr 23, 2012 2:11 pm
Wet foot wells could mean perhaps a hole/rust issue with the bulk head area, or the front wheel arches are holed and water is coming up as your driving along. the sunroof drains to the rear/boot of the car so don’t think that would be the cause of the problem.
mucka88
Post Wed Apr 25, 2012 6:20 pm
thanks for the comments guys, hoping to get over a pit the week end to check for rust and holes, checked out the wiki, and thumbs up to that :)
Post Wed Apr 25, 2012 6:49 pm
Rust :)
goosiegander
Zonegoose
Post Wed Apr 25, 2012 7:31 pm
ut-ho! doesn't sound good! 8O
Post Wed Apr 25, 2012 7:48 pm
mucka88 wrote:hiya, only brought my new e30 about 2 months ago, and now have noticed, water collecting the battery tray, and also in the footwells carpets am soaked, is this a common problem, i have the 1.8 4door with sunroof, so maybe thinking this could be a cause with drainage, not sure.... can anyone help? thanks
On a positive note , wet carpet =more weight ! :D
rich318i
Post Wed Apr 25, 2012 7:54 pm
if there soaked thats really not good about £500 worth of welding at least
Post Wed Apr 25, 2012 8:08 pm
rich318i wrote:if they're soaked that's really good , about £200 worth on the bridge at least
Fixed :)
goosiegander
Zonegoose
Post Wed Apr 25, 2012 8:35 pm
and i thought you ment downforce Peter LOL! :D
zaust
Zone day release
Post Wed Apr 25, 2012 8:39 pm
Really ?
M30 Tech 1 Touring on gas.
goosiegander
Zonegoose
Post Wed Apr 25, 2012 8:58 pm
Downforce in a moordoor essential...
mucka88
Post Tue May 08, 2012 10:12 pm
Right sorted problem I hope, after stripping interior it was the footwell bungs, they come out of place so put back in sealed, but drivers side jacking point was slighty cracked so welded. So all is dry again now . Thank you for the suggestions guys :)
