Will Frost's E30 track car build
Rallyprep_UK
formerly Driftnething
Post Thu Mar 08, 2012 10:46 pm
Hi chris,
Yes - I ran the car very low on fuel to reduce overall weight. I did not think about the effect the small amount of fuel sloshing around in there would have.
I would like to get some slicks also in the future, so in theory with the new setup I can get and maintain much harder cornering without needing 1/2 a tank of fuel. Thats the plan anyway ! :wink:
Will
Racing is living, everything else is just waiting...
http://www.rallyprep.co.uk
Rallyprep_UK
Post Thu Mar 08, 2012 10:54 pm
Demlotcrew wrote:Non sunroof model! Rare! :)
I'm going to pick up number two on saturday :cool:
S50b30 rally build coming up !
Demlotcrew
Post Thu Mar 08, 2012 11:26 pm
My fuel light was on and I still had no surges. :?
Post Thu Mar 08, 2012 11:55 pm
Demlotcrew wrote:My fuel light was on and I still had no surges. :?
+1
Never had a problem with the standard tank and pump, aftermarket pump fitted intank is a common problem as the pickup is different
Rallyprep_UK
Post Tue Mar 13, 2012 12:09 am
Driftnething wrote:
703 wrote:Hi mate nice set up there
I have same brake set up and the brake bias is way to much to the front, how do you find yours?
Putting bias valve in rear line will only reduce rear brake effect more???
let us know what your is like
I meant to ask what brake pads were you using ? You could run different front rear pad combinations to try and balance things out :wink:
Will
Another thought !!
Is there not an inline restrictor just after the master cyl on the line which goes to the rears ? What about removing that and fitting a bias valve instead if so :wink:
Back to the build...
The interior is now completely stripped and cleaned with white spirit, as is the boot.
I have removed the dash and un bolted the fusebox to allow access to the bulkhead/strut top area.
There was a fair bit more soundproofing behind the dash which obviously got removed.
I did find a nasty bit of rust just above where the loom passes throught the bulkhead though :cry:. oh well, nothing the welder wont fix I guess...
So I also weighed some of the bits which I removed out of interest. Weights are rough as I used some bathroom scales !
sport seat 23kgs ea
carpet 12kgs
sound deadening 10kgs
door cards, headlining and misc bits of plastic etc etc 15kgs
dash 8kgs
spare wheel, tools etc 15kgs
cd player, speakers, wires, aerial 5kgs
I make that roughly 100kgs gone so far and that is only the interior ! Dont forget I will be adding some weight back (cage, seats, harnesses, fire extinguisher kit.
But I will also continue to remove elsewhere - Bonnet, boot, gut the doors, lightweight windows, bumpers and supports etc...
On another note, my battery went flat !. No big deal right ?, well yes...
I jumped the car and drove it to the hose and left it running to charge while I gave it a scrub. Unfortunately it overheated severely (I dont think the fan cut in for some reason !? :cry: ). Anyway the engine has eaten its head gasket. Good job I have a spare but this made the "to do" list a lot bigger...
pics to follow...
Will
milescook
Post Tue Mar 13, 2012 11:34 am
Gutted on the cooked engine :( Interesting to see the weights.
Just remember if you haven't chucked out the centre console etc, (like I did!!! :o: ) they fetch a few quid in the for sale section 8)
Also please help the race budget by watching some videos :) https://www.youtube.com/cookracinguk
Rancid
Post Tue Mar 13, 2012 1:56 pm
Nice thread, will watch with interest :)
Pity about the engine roasting itself though :/
Formerly known as Rancido64.
e30less at present, working on that one....
-> Xbox360 Halo freak, GT: a wild Rancid
Mobile Phone Technical Support:
Got a problem with your mobile phone?
PM me and I'll do my best to help :)
Rallyprep_UK
Post Tue Mar 13, 2012 8:57 pm
milescook wrote:Gutted on the cooked engine :( Interesting to see the weights.
Good shout, thanks ! I have thrown nothing away and will do that :wink:.
Rancid wrote:Nice thread, will watch with interest :)
Thanks :wink:, I will try to take lots of pictures but usually just want to crack on lol. I am a bit gutted about the engine but the gearbox was due to be changed and I have a spare engine with less than the 160k this one had one it so it's not the end of the world I suppose. It is also a good excuse to sort (clean and paint) the engine bay black.
The interior is now fully stripped and I have finished cleaning. This pic was taken before the cleaning with white spirit was completed.
The removed dash etc...
The boot area has been emptied and also cleaned with white spirit/a brush/a cloth.
This shows the 10kgs of sound proofing removed. There was a load more in the hoover but I was not bothered about removing that to weigh it surprisingly !!!
I have also weighed the rear seat (15kgs !?!), and the dash is next up to be weighed.
The car is going back onto the scales tomorrow to check progress.
I have bought a battery cut off switch and am relocating the battery to the boot using the 0 awg battery cable from an e46 tourer. I dont like the fact that the E30 325 one is black and could be confused with the negative/earth !.
I bought some skateboard griptape to put in the drivers footwell as now they are slippery.
The interior is going to be painted "Audi Nimbus Grey"
(https://www.google.co.uk/search?hl=en&r ... 0QWDuISSBw).
The reasons being...
1. Black will make it too hot in the summer
2. If I decide to change the exterior colour it will still look ok
3. White is too hard to keep clean
4. It already has a good base colour meaning very little paint can be used (less weight !)
Thats it for today...
Will
Motorhole
Post Tue Mar 13, 2012 9:06 pm
Driftnething wrote: On another note, my spare (uncracked) dash has gone off to the GRP magicians so I can get a quote on having a grp mould made from it.
Hi mate, looks like a good job! Keep up the posting.
On another note, I would be interesting in knowing how much you get quoted for the grp dash. Is it worth a feeler in a group buy?
Rallyprep_UK
Post Tue Mar 13, 2012 9:23 pm
That is quite possible, Although it is looking expensive at the minute but the quality will be there.
There seems to be some good interest in these.
We have to pay for a mould to be produced from the standard dash which is not as easy as you may imagine due to its shape. I am currently awaiting a quote for this.
Then a professional must be paid to produce the dashboards from said mould, and then obviously there are material costs.
Next we have to pay sombody to flock them. But we shall see...
So stay tuned for more info... :-)
Will
Demlotcrew
Post Tue Mar 13, 2012 9:35 pm
Uwe had his car painted the same colour inside. I had mines done in satin black, no problems with heat during the summer.
Andrew
Rallyprep_UK
Post Tue Mar 13, 2012 10:30 pm
Demlotcrew wrote:Uwe had his car painted the same colour inside. I had mines done in satin black, no problems with heat during the summer.
Andrew
I guess great minds think alike !! :cool:
Satin black was next on my list but with;
black seats
black dash (flock)
black harness'es
light smoke window tint
I would be worried about being carjacked by Darth Vader...
redcar
Post Tue Mar 13, 2012 10:58 pm
Andrew
black seats
black dash (flock)
black harness'es
Stealth car! :mad:
dodgydoughnut
Post Wed Mar 14, 2012 6:32 am
if you remove your rear inline restictor from your brakes,put my name on it as i need a new one.(as long as its for rear discs)as mine from a drum model and over brakes the rear. :D
Post Wed Mar 14, 2012 8:10 am
Its not a restrictor, its a valve to stop the rears coming on with light braking.
The straight through one is for diagonally split systems.
See here - http://www.e30zone.net/modules.php?name ... ght=brakes
Demlotcrew
Post Wed Mar 14, 2012 8:55 am
Hmmm the one that came off my car was no valve, it was a restrictor, you could see right thought it, I just drilled a 4mm hole through the bronze part.
Andrew
Rallyprep_UK
Post Wed Mar 14, 2012 6:42 pm
Ahh. hmm, I am pretty sure mine is the smaller of the two and I just assumed (I should really stop assuming !) that it was a restrictor for the rears...
Will
Rallyprep_UK
Post Wed Mar 14, 2012 7:52 pm
PS. I just checked the weight of the dashboard and centre console/glove box lid. Thats 10kgs.
So a summary of the weights so far;
Sport seat 23kgs (each)
Door cards, headlining, shelf trim, and misc bits of plastic trim etc 15kgs
Rear seat (base and back - non armrest type) 15kgs
Spare wheel, tools etc 15kgs
Carpet 12kgs
Sound deadening 10kgs
Dashboard/centre console/glove box 10kgs
Cd player, speakers, wires, aerial/aerial cable 5kgs
redcar
Post Wed Mar 14, 2012 7:55 pm
Really nice car!
May i ask a quick question. Earlier you mentioned that when you converted to rear discs, you may have needed to change some valve. Is this the valve present on all e30s such as ones without ABS?
Rallyprep_UK
Post Wed Mar 14, 2012 7:58 pm
The grey and the red E30's were both M40 engined and drum braked rear ends. Neither had abs and of my cars (from memory) had the smaller part (not a valve bythe look of it).
Hope this helps. And I will double check when I get to work tomorrow :wink:
Will
dodgydoughnut
Post Wed Mar 14, 2012 10:01 pm
mine was a 320 with rear drums and no abs,converted to rear disc and eats rear pads,thought there was a rear restrictor in engine bay?
Rallyprep_UK
Post Thu Mar 15, 2012 9:04 pm
I weighed the car again today to check progress, it is now 1040kgs with about 10L of fuel on board !! Thats better than I was hoping !
dodgydoughnut
Post Fri Mar 16, 2012 6:13 am
do you think there is much more weight to be saved easyerly?
Rallyprep_UK
Post Fri Mar 16, 2012 7:06 pm
I have the windows, Bonnet and Boot to do which are the easy ones. And I expect that will be quite a lot of weight.
Then its time to gut the doors of their window mechs and central locking, and even the inner panel/door card.
Then the bumper mounts, and even the bumpers may get replaced for GRP too.
So yes there is still a lot of weight to remove. I want to be around 1000kgs and 300bhp ideally, thats the target.
Will
rix313
Post Sat Mar 17, 2012 11:20 am
That's quite impressive with basic stripping :)
Rallyprep_UK
Post Sat Mar 17, 2012 1:22 pm
I must admit, I was definitely not expecting to lose that much this easily !!.
It is good news :cool:
rix313
Post Sat Mar 17, 2012 3:03 pm
Time to add it back in now with some metal tubing 8)
Post Sat Apr 07, 2012 7:36 pm
Weighed any engines yet Will? :D
Rallyprep_UK
Post Sat Apr 07, 2012 7:46 pm
Nope :(, not yet mate - the engine is coming out in a week or so tho :wink: .
I am working on the red car at the minute. I do need to get this one up to Caged A.S.A.P ! I am itching to have the climbing frame installed ! I am leaning toward a more simple design though now (to save weight). I am also swapping the diff cover for an E36 item which they will fabricate a mount for at the same time hopefully. :D
Post Sat Apr 07, 2012 7:56 pm
Look forward to the pics :cool:
dodgydoughnut
Post Sun Apr 15, 2012 2:59 pm
keep us informed about e36 rear diff cover,seams a good mod,mine has polybush and has collapesd after 12 months
Rallyprep_UK
Post Mon Apr 16, 2012 10:28 pm
dodgydoughnut wrote:keep us informed about e36 rear diff cover,seams a good mod,mine has polybush and has collapesd after 12 months
Cool yes I will do mate , actually I have found somebody who sells a conversion kit comprising of the brackets (to weld to the car), a template, and a blasted/powdercoated e36 diff cover and all fixings ! - I will find the details and pm you :wink:.
On other news, I picked up some manifolds today to have a play with...
There is no way I am spending the huge amount it costs to obtain a BTB manifold. At the end of the day its a chopped up standard part !! I know they are of high quality and a good design but at the end of the day I have some VERY good motorsport engineers and fabricators which I can get to essentially copy the same design.
Watch this space..
And before you ask ! No !, I did not modify that manifold and am not going to use it like that ! They were cheap and that is how I bought them. In the worst case it is spare bits of pipe/flanges :cool:.
Will
Rallyprep_UK
Post Wed Jul 25, 2012 6:58 pm
The old girl is finally home, work can begin on tarting it up/swapping the engine.
The head gasket failure engine is out. The replacement is being prepared.
Demlotcrew
Post Wed Mar 20, 2013 4:25 pm
Topic moved in here :)
Rallyprep_UK
Post Wed Mar 20, 2013 5:25 pm
Hi Andrew, what has moved here !?
I have not worked on this car for ages :cry:.
But have been busy on some other nice ones :D.
Will
