What rad?
phi1
Post Fri Feb 10, 2012 8:43 am
Hi there I am getting to the part in my build where I am going to require a rad what is best to use in the e30? I have read about using an e36 m3 one but want to make sure it will be suffiant at cooling the m60 lump!
Phill172
Post Fri Feb 10, 2012 9:21 am
I run a e36 m3 rad, cooling is fine on road etc, I had a few issues when drifting, be it that is a massive demand on the car, and going sideways you dont get the flow of air.
Basically driving it a straight line, track, sitting in traffic it was fine.
The e36 m3 actually has a core thats around 10mm thicker, so the overall size between the two radiators isnt much. Also benifit of the m3 rad is it goes straight in, no cutting of rails needed!
If you are worried there is a couple of companies that can make a bespoke alloy rad. Something I will upgrade too
Driftben
Post Sat Feb 11, 2012 8:00 am
Yep im using the e28 535i too, fits well.
6pot wilwoods front
4pot Porsche rear
89 E30 stripped running a 6speed V8
Twin Turbo M60 in progress
FormerMember
Post Tue Feb 14, 2012 8:09 am
E28 rad and E36 M3 rad do fit, but at least here in hot Finland 8) they are not good enough - though that could be probably solved with more powerful fan..
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
vokietis
Post Tue Feb 14, 2012 4:01 pm
E36 325tds fits easy,also e30 324d 324td very good choice
padi
Post Mon Oct 22, 2012 9:59 pm
Can anyone tell me does the 535 rad just bolt straight in?
Cheers Chris
Phill172
Post Tue Oct 23, 2012 9:21 am
http://www.mishimoto.co.uk/mishimoto-bm ... 99-02.html
this will fit and quality is amazing
padi
Post Tue Oct 23, 2012 11:57 am
I'm currently running re 318 standard rad, but I'm just trying to collect some parts before I start tearing the car apart. I was thinking I'd run re e36 M3 rad as its a direct fit, but wondered if tere was a benefit to running the 535 rad to be honest.
Cheers Chris.
