M20B25 valve guides
spewy555
ross2009
any decent engine shop should be able to get them my local guy got mine easy
SilverShadow
- Hartge Crew
silly questions but why are you replacing the guides?
why not ream them and use larger valves?
ross2009
the only guides that will need replacing are the exhaust guides as they wear alot more the inlet side should be the same as from factory
SilverShadow
- Hartge Crew
so the machine shop would just pop the old ones out and replace the new ones - so that you use your current valves?
ross2009
yeah theres no need to replace the valves they will be fine if its done average milage
but having said that they do ream the new ones to suit which ever valve you use
spewy555
ross2009
I could have got you some from my guy I use
Ant
- Retired Team Member
reamed out stock guides with OS ( stem) valves are a no win IMHO
More valve train friction, heavier valve...........
less is defo more
less is defo more
Email FTW
ross2009
who said anything about oversize valves lolspewy555 wrote:It is just the exhaust guides as they are very poor. I have had some made now as everyone that listed them off the shelf had none in stock with no delivery date.
Bloody expensive to change the valves just because the guides are oversize!
