M20B25 valve guides
- Hartge Crew
silly questions but why are you replacing the guides?
why not ream them and use larger valves?
- Hartge Crew
so the machine shop would just pop the old ones out and replace the new ones - so that you use your current valves?
- Retired Team Member
- Contact:
reamed out stock guides with OS ( stem) valves are a no win IMHO
More valve train friction, heavier valve...........
less is defo more
less is defo more
Email FTW
who said anything about oversize valves lolspewy555 wrote:It is just the exhaust guides as they are very poor. I have had some made now as everyone that listed them off the shelf had none in stock with no delivery date.
Bloody expensive to change the valves just because the guides are oversize!
