E36 cill delete option
Post Wed Nov 09, 2011 8:26 pm
How are your e36 cills? heres mine
wow e30 styleee rot. Its like a northern scotch car!! this is why you don't drive them with the plastic bungs. Was the only one missing when i bought the car. Guess it was too late. I haven't even taken the skirt off!
glenn
Engine Transplant Services
Post Wed Nov 09, 2011 8:36 pm
i've got an e36 coupe breaking here in actic silver si, let me know if you need any plastic bungs and i'll get them in the post
nickso
Post Wed Nov 09, 2011 8:40 pm
My northern scotch car has the beginnings of this too. Also on the side where the bung was missing, mine is saveable though. I may tidy it up in the summer if it's not too late.
'88 e30 328i M52 track bint.
Post Wed Nov 09, 2011 8:59 pm
Same thing will happen to E46's in time to come.
Countless BMW's pass through work with the jacking block/bung missing. I always report them on the health checks.
Post Wed Nov 09, 2011 9:03 pm
Ouch.
4dr turd. All corners of this car were rotten.
e30kev
Post Wed Nov 09, 2011 9:04 pm
mine has this in the same place on the rear nearside, being welded :(
Post Wed Nov 09, 2011 9:12 pm
to be fair i think its an easy repair. they are a farily large box section on the e36. Just thought i'd share it!
Cook318IS
Post Wed Nov 09, 2011 9:15 pm
My e36 donor i had, originally from scotland. The rustiest e36 i had ever seen :?
Post Wed Nov 09, 2011 9:18 pm
I remember the other pics! Its rust on rust! 8O
Ajsingh
Post Wed Nov 09, 2011 9:32 pm
bss325i wrote:Same thing will happen to E46's in time to come.
+1..
Newer cars are slightly worse off, the jacking blocks just push and clip in. Not the best IMO
E30 Crazy!
Post Wed Nov 09, 2011 9:58 pm
Cook318IS wrote:My e36 donor i had, originally from scotland. The rustiest e36 i had ever seen :?
That fooker had been in the sea, no doubt about it!
Until the bods at BMW sit the ignorant customer down and explain to them that unless they have the lower plastic trims/arch liners removed and the body cleaned/protected the cars will continue to degrade and eventually fall apart.
But I suspect there is a very good reason they dont do that :)
Post Wed Nov 09, 2011 10:51 pm
DanThe wrote:Until the bods at BMW sit the ignorant customer down and explain to them that unless they have the lower plastic trims/arch liners removed and the body cleaned/protected the cars will continue to degrade and eventually fall apart.
I nearly fell over when i was asked to wire brush and wax oil some brake and fuel lines on an E34 at work!
Still, the owner has dropped 6k on it in the last year! :eek:
He's coming back for another bags worth in the new year! :mad:
Post Fri Nov 11, 2011 5:18 pm
i dare look under my compact :mad:
Post Fri Nov 11, 2011 5:39 pm
Alex wrote:i dare look under my compact :mad:
Don't worry Alex, P40 doesn't rust, so Topless tells me :)
This is now a fairly common occurence with E36s . As with E30s and E34s, the cars with sideskirts are usually the worst affected.
Trolley jack wielding beasts attacking sills with MIA jacking bungs are responsible for lots of the ensuing rust and carnage,
Dezzy
CR24v it's a lifestyle
Post Fri Nov 11, 2011 9:28 pm
Pete, you don't need steve to tell you anything about catipulting P40!
Post Fri Nov 11, 2011 9:38 pm
Dezzy wrote:Pete, you don't need steve to tell you anything about catipulting P40!
Murphy is the new zone P40 god ! :o :)
Post Fri Nov 11, 2011 9:45 pm
P40 is a ghetto repair
Pigeon shit + P40 = upmarket ghetto repair winkeye
Post Fri Nov 11, 2011 11:29 pm
I was thinking solder looks quite strong whilst I was attepting (Failing) to fix my LKM module. :)
harry_p
Post Sat Nov 12, 2011 1:13 am
I keep meaning to have a prod under mine. The rear arches are a mess, but everything else looks pretty solid. With all these horror stories I'm going to have to take the skirts off at some point for a proper investigation :mad:
cheers,
harry
