wow e30 styleee rot. Its like a northern scotch car!! this is why you don't drive them with the plastic bungs. Was the only one missing when i bought the car. Guess it was too late. I haven't even taken the skirt off!
+1..bss325i wrote:Same thing will happen to E46's in time to come.
Countless BMW's pass through work with the jacking block/bung missing. I always report them on the health checks.
That fooker had been in the sea, no doubt about it!Cook318IS wrote:My e36 donor i had, originally from scotland. The rustiest e36 i had ever seen
I nearly fell over when i was asked to wire brush and wax oil some brake and fuel lines on an E34 at work!DanThe wrote:Until the bods at BMW sit the ignorant customer down and explain to them that unless they have the lower plastic trims/arch liners removed and the body cleaned/protected the cars will continue to degrade and eventually fall apart.
But I suspect there is a very good reason they dont do that
Alex wrote:i dare look under my compact
Dezzy wrote:Pete, you don't need steve to tell you anything about catipulting P40!
