M42 Rebuild
jimbom30cab
- Tech 1 freak
just finished re-building this m42 lump - really pleased with the look, hope it runs ok!!
ah
If the car looks as good as that, its going to one damn nice combination!
Born on the 23 April 1990 320i Alpinweiss ll kabriolett! (SOLD BUT NOT FORGOTTEN !)
BEERBOY123
That is awesome
Two headblenders, couple of bags of MC Hammer, 5 litres of FFF, a 48ft bastard, a box of jumped-up custard and some soggy chimps
parkin10
well shiny
jimbom30cab
- Tech 1 freak
thanks guys, i hope it runs ok, not 100% confident the profile gasket has a good seal...
Cook318IS
Thats a very good effort! Looks brand new
I'd be sorting out the profile gasket if you are not 100% happy - you'd kick yourself if you put it in and it leaked.
jimbom30cab
- Tech 1 freak
yer, i was thinking exactly the same mate but needed to be told to just do it!!!! you know what its like....
redcar
How many miles has it done?
If its quite a low mileage one, chances are that the profile gasket hasn't been changed for the stronger type. See its got the metal oil filter housing, likely to be an older engine though.
appletree
if its still out of the car just check this gasket before you put it back in.
http://www.e30zone.net/modules.php?name ... hlight=m42
jimbom30cab
- Tech 1 freak
thanks guys and thanks for the link - will check that also, just as soon as i've finished sorting out the leaking bath waste pipe
Eddie25
Factory fresh
Rust is lighter than carbon fibre.
rix313
Eddie25 wrote:Factory fresh
Pics of the car it's going into?
TPS
This!
jimbom30cab
- Tech 1 freak
hope it works ok mate, should be good
TPS
Thanks Jim, I'm sure we'll be alright
G-Bear
That M42 looks fantastic.. What work has gone into the rebuild?
kangman
MY FACEBOOK PAGE- CLASSIC STANCE
http://www.facebook.com/pages/Classic-S ... 6444884427
MY FOUR EYED BEAST
MY FOUR EYED BEAST
oomz1975
TPS
Its had new gaskets/seals/hoses, cleaned injectors, the inlet & cam cover has been sprayed, new Water pump/'stat, fresh oil & plugs, loads of parts & attention have been showered on this.G-Bear wrote:That M42 looks fantastic.. What work has gone into the rebuild?
G-Bear
Cheers TPS, got an IS in my sisters garage, its got some rot that I hope to fix then going to pull the lump out for an overhaul. Always temped to frag it and forget it but this tread has held be back a bit..TPS wrote:Its had new gaskets/seals/hoses, cleaned injectors, the inlet & cam cover has been sprayed, new Water pump/'stat, fresh oil & plugs, loads of parts & attention have been showered on this.G-Bear wrote:That M42 looks fantastic.. What work has gone into the rebuild?
I take it this ones for you for the Touring in the pics above, good luck with it hope you put some pictures up on here..
Jozi
I used to have a m42 in my touring, not a bad combo I thought. Engine looks spotless!
TPS
Thanks, it is going into the Touring, I will put some photos up.G-Bear wrote:Cheers TPS, got an IS in my sisters garage, its got some rot that I hope to fix then going to pull the lump out for an overhaul. Always temped to frag it and forget it but this tread has held be back a bit..TPS wrote:Its had new gaskets/seals/hoses, cleaned injectors, the inlet & cam cover has been sprayed, new Water pump/'stat, fresh oil & plugs, loads of parts & attention have been showered on this.G-Bear wrote:That M42 looks fantastic.. What work has gone into the rebuild?
TPS
jmc330i
Looks tidy dude. Do I spy the obligatory zip-tie holding the coil packs on? Lol
Was it worth doing over the M40?
Another quick question as you've fitted this to a '94 car, what have you done for the exhaust? Are you running a cat or is it ok for emissions without?
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
jimbom30cab
- Tech 1 freak
WTF is going on with that AFM and air box - get them cleaned up like yesterday !!
bigredbmw
- Zone Supporter
my m40 1.8 lump fully rebuilt
jimbom30cab
- Tech 1 freak
VERY VERY NICE
mr_dink
I used to have a 94 touring with an IS engine, MOT regs are that its tested on the oldest part of the car.jmc330i wrote:Looks tidy dude. Do I spy the obligatory zip-tie holding the coil packs on? Lol
My engine was out of a 1990 car, went along to MOT with a letter from a garage stating that a 1990 engine was fitted, passed MOT without a cat.
jmc330i
Yup, same as my S50 conversion, obviously the car was older than engine.mr_dink wrote:I used to have a 94 touring with an IS engine, MOT regs are that its tested on the oldest part of the car.jmc330i wrote:Looks tidy dude. Do I spy the obligatory zip-tie holding the coil packs on? Lol
Sorry, I was getting confused, I thought tps was using a newer M42. Mine is actually an M44 and the touring is a 93, so I may have issues without a cat.
James
'91 325i Sport
'91 325i Sport
jimbom30cab
- Tech 1 freak
did over 300 miles in this M42 today and it ran as sweet as a sewing machine, a really lovely engine, pulled well, reved high, sounded fab ....great MPG also.
the m42 is a good little fizz bomb .
+ a yard full of scrap turds
jon-m42
If i must say this looks very clean indeed ... do enjoy it when you have it all up and running.
McGoo
very clean engine, looks nice. shame you didnt keep track of the full rebuild on here..
ill be rebuilding my 42' soon aswell
The_Diddler
- Love it up the more door !
Nice, looks good in the bay, as said get that airbox sorted
