M42 Rebuild
jimbom30cab
Tech 1 freak
Post Mon Oct 31, 2011 10:10 pm
just finished re-building this m42 lump - really pleased with the look, hope it runs ok!!
ajay
Post Tue Nov 01, 2011 11:01 pm
That sure looks good matey!
ah
Post Tue Nov 01, 2011 11:07 pm
If the car looks as good as that, its going to one damn nice combination!
BEERBOY123
Post Fri Nov 04, 2011 6:31 pm
That is awesome
Two headblenders, couple of bags of MC Hammer, 5 litres of FFF, a 48ft bastard, a box of jumped-up custard and some soggy chimps
parkin10
Post Fri Nov 04, 2011 9:28 pm
well shiny
jimbom30cab
Tech 1 freak
Post Sat Nov 05, 2011 6:35 pm
thanks guys, i hope it runs ok, not 100% confident the profile gasket has a good seal...
Cook318IS
Post Sat Nov 05, 2011 6:48 pm
Thats a very good effort! Looks brand new :D I'd be sorting out the profile gasket if you are not 100% happy - you'd kick yourself if you put it in and it leaked.
jimbom30cab
Tech 1 freak
Post Sat Nov 05, 2011 7:48 pm
yer, i was thinking exactly the same mate but needed to be told to just do it!!!! you know what its like....
redcar
Post Sun Nov 06, 2011 9:29 am
How many miles has it done?
If its quite a low mileage one, chances are that the profile gasket hasn't been changed for the stronger type. See its got the metal oil filter housing, likely to be an older engine though.
appletree
Post Sun Nov 06, 2011 4:17 pm
if its still out of the car just check this gasket before you put it back in.
http://www.e30zone.net/modules.php?name ... hlight=m42
jimbom30cab
Tech 1 freak
Post Tue Nov 08, 2011 8:49 pm
thanks guys and thanks for the link - will check that also, just as soon as i've finished sorting out the leaking bath waste pipe :(
Eddie25
Post Wed Nov 09, 2011 11:44 am
Factory fresh :cool:
Rust is lighter than carbon fibre.
rix313
Post Wed Nov 09, 2011 1:18 pm
Eddie25 wrote:Factory fresh :cool:
8) 8)
Pics of the car it's going into?
TPS
Post Sun Nov 04, 2012 10:36 pm
This!
jimbom30cab
Tech 1 freak
Post Sun Nov 04, 2012 11:04 pm
hope it works ok mate, should be good
TPS
Post Sun Nov 04, 2012 11:10 pm
Thanks Jim, I'm sure we'll be alright
G-Bear
Post Mon Nov 05, 2012 9:46 pm
That M42 looks fantastic.. What work has gone into the rebuild?
kangman
Post Mon Nov 05, 2012 10:33 pm
:drool:
oomz1975
Post Mon Nov 05, 2012 11:08 pm
Nice work, looks minty fresh.
TPS
Post Tue Nov 06, 2012 6:56 am
G-Bear wrote:That M42 looks fantastic.. What work has gone into the rebuild?
Its had new gaskets/seals/hoses, cleaned injectors, the inlet & cam cover has been sprayed, new Water pump/'stat, fresh oil & plugs, loads of parts & attention have been showered on this.
G-Bear
Post Tue Nov 06, 2012 8:11 am
Cheers TPS, got an IS in my sisters garage, its got some rot that I hope to fix then going to pull the lump out for an overhaul. Always temped to frag it and forget it but this tread has held be back a bit..
I take it this ones for you for the Touring in the pics above, good luck with it hope you put some pictures up on here.. :D
Jozi
Post Tue Nov 06, 2012 11:06 am
I used to have a m42 in my touring, not a bad combo I thought. Engine looks spotless!
TPS
Post Wed Nov 07, 2012 3:18 pm
Thanks, it is going into the Touring, I will put some photos up.
TPS
Post Wed Dec 19, 2012 6:54 am
jmc330i
Post Wed Dec 19, 2012 8:45 am
Looks tidy dude. Do I spy the obligatory zip-tie holding the coil packs on? Lol
Was it worth doing over the M40?
Another quick question as you've fitted this to a '94 car, what have you done for the exhaust? Are you running a cat or is it ok for emissions without?
James
'91 325i Sport
'93 318i touring 16v
jimbom30cab
Tech 1 freak
Post Wed Dec 19, 2012 8:55 am
WTF is going on with that AFM and air box - get them cleaned up like yesterday !!
bigredbmw
Zone Supporter
Post Wed Dec 19, 2012 3:24 pm
my m40 1.8 lump fully rebuilt
jimbom30cab
Tech 1 freak
Post Wed Dec 19, 2012 3:30 pm
VERY VERY NICE
mr_dink
Post Wed Dec 19, 2012 3:42 pm
jmc330i wrote:Looks tidy dude. Do I spy the obligatory zip-tie holding the coil packs on? Lol
I used to have a 94 touring with an IS engine, MOT regs are that its tested on the oldest part of the car.
My engine was out of a 1990 car, went along to MOT with a letter from a garage stating that a 1990 engine was fitted, passed MOT without a cat.
jmc330i
Post Wed Dec 19, 2012 9:22 pm
Yup, same as my S50 conversion, obviously the car was older than engine.
Sorry, I was getting confused, I thought tps was using a newer M42. Mine is actually an M44 and the touring is a 93, so I may have issues without a cat.
James
'91 325i Sport
jimbom30cab
Tech 1 freak
Post Sun Dec 23, 2012 9:55 pm
did over 300 miles in this M42 today and it ran as sweet as a sewing machine, a really lovely engine, pulled well, reved high, sounded fab ....great MPG also.
Post Sun Dec 23, 2012 10:17 pm
the m42 is a good little fizz bomb .
jon-m42
Post Mon Dec 24, 2012 12:36 pm
If i must say this looks very clean indeed ... do enjoy it when you have it all up and running. :wink:
McGoo
Post Mon Jan 21, 2013 5:12 pm
very clean engine, looks nice. shame you didnt keep track of the full rebuild on here..
ill be rebuilding my 42' soon aswell
The_Diddler
Love it up the more door !
Post Mon Jan 21, 2013 5:16 pm
Nice, looks good in the bay, as said get that airbox sorted :D :D
