MugelloRot M52 Touring>Selling up!!
eko
Old timer
Post Sat Apr 09, 2011 9:18 pm
Dont mind buying a key really,afterall the donor was a steal and flogged a few parts plus weighed the shell so £20 on a valet key isnt the end of the world!
Post Sat Apr 09, 2011 9:23 pm
Basic key was £36 last time I bought one Rob, the one with the remote is over £100 now :mad:
Check with your parts guys what docs they want to see before you go Tony, im pretty sure the address on logbook and your drivers licence need to match. There are ways around it if they dont winkeye
eko
Old timer
Post Sun Apr 10, 2011 10:34 pm
DanThe wrote:Basic key was £36 last time I bought one Rob, the one with the remote is over £100 now :mad:
I ordered a valet key for a Compact breaker recently and they didnt want to see anything winkeye
Stripped the M40 out today and gave the engine bay a clean up.
Will fit the servo and rack tomorrow then the M52 can be slotted in.
Bye :D
Post Sun Apr 10, 2011 10:43 pm
Nice clean bay there 8)
eko
Old timer
Post Mon Apr 11, 2011 5:40 pm
Cant be bothered with it today as im knackered.
Good news though,went to the scrappies where the E36 donor got taken too and low and behold its still on the pile so I managed to get the ignition key back :P
Post Mon Apr 11, 2011 5:58 pm
eko wrote:Cant be bothered with it today as im knackered.
you lucky bugga 8)
Cook318IS
Post Mon Apr 11, 2011 6:02 pm
I have a brand new genuine bmw oil filter for one of those types of oil filter housings should you require one :wink:
eko
Old timer
Post Mon Apr 11, 2011 8:36 pm
Cook318IS wrote:I have a brand new genuine bmw oil filter for one of those types of oil filter housings should you require one :wink:
That would be good mate :wink:
Also,you still got the print out for the wiring/EWS we used for yours?
dont suppose I could get a copy from you please?
Cook318IS
Post Mon Apr 11, 2011 8:39 pm
Yeah, with all that addition gumpf i looked at with the ews saga. You going to need the bits by saturday? I'll nip over saturday morning unless you need it during the week :wink:
eko
Old timer
Post Mon Apr 11, 2011 8:41 pm
Saturday is fine mate,doubt ill get that far before then :cool:
eko
Old timer
Post Tue Apr 12, 2011 8:43 pm
Engine in :D
Cook318IS
Post Tue Apr 12, 2011 9:53 pm
Awesome :cool: Did it slot straight in or did you have trouble like we did with mine not wanting to go onto the mounts?
eko
Old timer
Post Tue Apr 12, 2011 10:05 pm
Cook318IS wrote:Awesome :cool: Did it slot straight in or did you have trouble like we did with mine not wanting to go onto the mounts?
Slotted straight in mate.
Put the E36 rack and Clio servo in first as you do,overall good couple of hours :D
Cook318IS
You make it sound like you've done this before? :P
eko
Old timer
Post Tue Apr 12, 2011 10:12 pm
Cook318IS wrote:You make it sound like you've done this before? :P
First in a while mate and I pissed off with all the crap everywhere and oil stained hands :cry:
Will be worth it though :drive:
eko
Old timer
Post Sat Apr 16, 2011 9:48 pm
Few more bit done today.
Collected an E30 prop bearing so got the E36 prop fitted,gear linkage all done and clutch slave plumbed in.
Steering pipes refitted and refilled.
Finally my manifolds are all but finished,just needed the welds polishing back earlier when I went and saw them so hopefully ill have them by tomorrow.
So plans for in the morning are get the E36 Compact fan stripped from its huge plastic frame and mount that ready to be wired up.
Radiator can then go in and coolant then added.
Steering linkage on its way from Danthe.
Then its more or less just the wiring and a tidy up :D
shedrool83
Post Sat Apr 16, 2011 10:00 pm
Not far away now Tony.
Going to be creaking when done.
eko
Old timer
Post Sun Apr 17, 2011 8:40 pm
Couple more jobs to tick off the list..
Clutch bled
Exhaust manifolds fitted
Electric fan fitted(still needs wiring)
Radiator fitted and filled
Matrix pipes connected
Throttle cable connected
Rear valance cut out to fit twin exit backbox
Brackets made for M52 fuel rail
Starter motor fitted
Main jobs now are to wire the lump up and finish the exhaust.
Oh and fit the diff but waiting on backplate and output shafts for that.
monkey
Post Sun Apr 17, 2011 8:46 pm
well done tony :) get it finished chap as you have been driving a 4pot for too long now
eko
Old timer
Post Sun Apr 17, 2011 8:50 pm
Im trying Matt :P
Fancy rigging the twin speed fan at some point for me mate?
All components are fitted,just needs wires routed.
Do I need to get some fuse connectors/tails from the dealers,pretty sure I need a couple dont I?
monkey
Post Sun Apr 17, 2011 9:02 pm
eko wrote:Im trying Matt :P
yea we can get it sorted one weekend mate . i will give you a ring or pop in one evening during the week
eko
Old timer
Post Sun Apr 17, 2011 11:08 pm
Ok mate
eko
Old timer
Post Tue Apr 19, 2011 11:27 pm
Engine all but wired in now.
couple of wires still to be connected then it can be fitted into the M40 wiring cover.
Fingers crossed no reason why it cant be drivable by weekend
eko
Old timer
Post Wed Apr 20, 2011 11:09 pm
Nearly done now.
Engine loom finished,just got the EWS to finish off so I can crank it over.
Exhaust is going to need some work to make fit properly which will be attended to on Saturday.
Other than that its just really doing all the fluids etc to be able to fire it up.
Post Wed Apr 20, 2011 11:20 pm
looks the business mate
Post Thu Apr 21, 2011 7:17 am
Tidy that is :cool:
I'm having thoughts about an M52 project when my touring is finished - just need to move house first so I have more space :twisted:
eko
Old timer
Post Thu Apr 21, 2011 11:26 pm
3.38 Compact diff now fitted.Just got to swap the output shafts over and bolts the shafts back up.
Oil,pas fluid,coolant done for now.
Danthe steering coupling fitted.
Ive still got the EWS to fit but have got it all laid out ready to go in.
Mate coming over tomorow with his Tig to do some work on the exhaust and ive got to put a bigger spacer in the servo as the pedal is a bit too low now.
Starting to take shape now.
THEHOOD
Post Fri Apr 22, 2011 9:34 pm
Looking really good! top effort. :cool:
eko
Old timer
Post Fri Apr 22, 2011 10:56 pm
THEHOOD wrote:Looking really good! top effort. :cool:
Cheers :D
Had my mate over today to get the exhaust fitted.
Bit of a mix `n`match stainless system comprising of Unknown make backbox and M3 Scorpion centre.
He has had to make up sections to go inbetween the Scorpion and downpipes around 900mm long.
Looks awsome im just afraid its going to be mega loud as it on.y has a huge rear silencer and tiny resonator type box in the Scorpion.
Think it will need another silencer fitting towards the front but ill see how it is first.
Hopefully ill have a go at firing it up tomorrow :D
monkey
Post Sat Apr 23, 2011 2:53 pm
is running yet Tony ?
eko
Old timer
Post Sat Apr 23, 2011 9:53 pm
monkey wrote:is running yet Tony ?
Not tried it yet mate as ive still got to fit the EWS under the dash but cant open the doors wide enough without banging them on the wall so will roll it back down the drive a bit too do that.
Ive put the battery in though and done a ignition key test and all dash lights ok.Does actually try to crank over but the starter is just whizzing round so ill have to see whats going on with that.
Exhaust is done and fitted now.
Rear valance needs opening upa bit more but I purposly cut it undersize untill final fit and still needs a gearbox mount fitting.
Waiting on output shafts for the diff which will hopefully be Monday.
Ran the polisher over one of my wheels as they are looking terrible after the winter weather.
Still not perfect(I havent got the patience really) but much better than before.
Bastard is ill have to do the other 3 now :cry:
Post Sat Apr 23, 2011 10:16 pm
Awesome progress in a short space of time. 8)
Post Sat Apr 23, 2011 10:27 pm
Exhaust bling :D
Jozi
Post Sat Apr 23, 2011 11:51 pm
I need you here Eko, my touring would be finished by now :D Good progress :thumb: Liking the exhaust system to.
Cook318IS
Post Sun Apr 24, 2011 12:26 am
That exhaust is the absolute shiz!
