MugelloRot M52 Touring>Selling up!!
eko
- Old timer
Dont mind buying a key really,afterall the donor was a steal and flogged a few parts plus weighed the shell so £20 on a valet key isnt the end of the world!
Basic key was £36 last time I bought one Rob, the one with the remote is over £100 now
Check with your parts guys what docs they want to see before you go Tony, im pretty sure the address on logbook and your drivers licence need to match. There are ways around it if they dont
eko
- Old timer
I ordered a valet key for a Compact breaker recently and they didnt want to see anythingDanThe wrote:Basic key was £36 last time I bought one Rob, the one with the remote is over £100 now![]()
Stripped the M40 out today and gave the engine bay a clean up.
Will fit the servo and rack tomorrow then the M52 can be slotted in.
Bye
Nice clean bay there
eko
- Old timer
Cant be bothered with it today as im knackered.
Good news though,went to the scrappies where the E36 donor got taken too and low and behold its still on the pile so I managed to get the ignition key back
you lucky buggaeko wrote:Cant be bothered with it today as im knackered.
+ a yard full of scrap turds
Cook318IS
I have a brand new genuine bmw oil filter for one of those types of oil filter housings should you require one
eko
- Old timer
That would be good mateCook318IS wrote:I have a brand new genuine bmw oil filter for one of those types of oil filter housings should you require one
Also,you still got the print out for the wiring/EWS we used for yours?
dont suppose I could get a copy from you please?
Cook318IS
Yeah, with all that addition gumpf i looked at with the ews saga. You going to need the bits by saturday? I'll nip over saturday morning unless you need it during the weekeko wrote:That would be good mateCook318IS wrote:I have a brand new genuine bmw oil filter for one of those types of oil filter housings should you require one![]()
eko
- Old timer
Saturday is fine mate,doubt ill get that far before thenCook318IS wrote:Yeah, with all that addition gumpf i looked at with the ews saga. You going to need the bits by saturday? I'll nip over saturday morning unless you need it during the weekeko wrote:That would be good mateCook318IS wrote:I have a brand new genuine bmw oil filter for one of those types of oil filter housings should you require one![]()
Cook318IS
Awesome
Did it slot straight in or did you have trouble like we did with mine not wanting to go onto the mounts?
eko
- Old timer
Slotted straight in mate.Cook318IS wrote:AwesomeDid it slot straight in or did you have trouble like we did with mine not wanting to go onto the mounts?
Put the E36 rack and Clio servo in first as you do,overall good couple of hours
Cook318IS
You make it sound like you've done this before?
eko
- Old timer
First in a while mate and I pissed off with all the crap everywhere and oil stained handsCook318IS wrote:You make it sound like you've done this before?
Will be worth it though
eko
- Old timer
Few more bit done today.
Collected an E30 prop bearing so got the E36 prop fitted,gear linkage all done and clutch slave plumbed in.
Steering pipes refitted and refilled.
Finally my manifolds are all but finished,just needed the welds polishing back earlier when I went and saw them so hopefully ill have them by tomorrow.
So plans for in the morning are get the E36 Compact fan stripped from its huge plastic frame and mount that ready to be wired up.
Radiator can then go in and coolant then added.
Steering linkage on its way from Danthe.
Then its more or less just the wiring and a tidy up
shedrool83
eko
- Old timer
Couple more jobs to tick off the list..
Clutch bled
Exhaust manifolds fitted
Electric fan fitted(still needs wiring)
Radiator fitted and filled
Matrix pipes connected
Throttle cable connected
Rear valance cut out to fit twin exit backbox
Brackets made for M52 fuel rail
Starter motor fitted
Main jobs now are to wire the lump up and finish the exhaust.
Oh and fit the diff but waiting on backplate and output shafts for that.
Clutch bled
monkey
well done tony
get it finished chap as you have been driving a 4pot for too long now
eko
- Old timer
Im trying Matt
Fancy rigging the twin speed fan at some point for me mate?
All components are fitted,just needs wires routed.
Do I need to get some fuse connectors/tails from the dealers,pretty sure I need a couple dont I?
monkey
yea we can get it sorted one weekend mate . i will give you a ring or pop in one evening during the weekeko wrote:Im trying Matt![]()
eko
- Old timer
Ok matemonkey wrote:yea we can get it sorted one weekend mate . i will give you a ring or pop in one evening during the weekeko wrote:Im trying Matt![]()
eko
- Old timer
Engine all but wired in now.
couple of wires still to be connected then it can be fitted into the M40 wiring cover.
Fingers crossed no reason why it cant be drivable by weekend
eko
- Old timer
Nearly done now.
Engine loom finished,just got the EWS to finish off so I can crank it over.
Exhaust is going to need some work to make fit properly which will be attended to on Saturday.
Other than that its just really doing all the fluids etc to be able to fire it up.
looks the business mate
Tidy that is
I'm having thoughts about an M52 project when my touring is finished - just need to move house first so I have more space
eko
- Old timer
3.38 Compact diff now fitted.Just got to swap the output shafts over and bolts the shafts back up.
Oil,pas fluid,coolant done for now.
Danthe steering coupling fitted.
Ive still got the EWS to fit but have got it all laid out ready to go in.
Mate coming over tomorow with his Tig to do some work on the exhaust and ive got to put a bigger spacer in the servo as the pedal is a bit too low now.
Starting to take shape now.
THEHOOD
Looking really good! top effort.
eko
- Old timer
CheersTHEHOOD wrote:Looking really good! top effort.
Had my mate over today to get the exhaust fitted.
Bit of a mix `n`match stainless system comprising of Unknown make backbox and M3 Scorpion centre.
He has had to make up sections to go inbetween the Scorpion and downpipes around 900mm long.
Looks awsome im just afraid its going to be mega loud as it on.y has a huge rear silencer and tiny resonator type box in the Scorpion.
Think it will need another silencer fitting towards the front but ill see how it is first.
Hopefully ill have a go at firing it up tomorrow
monkey
is running yet Tony ?
eko
- Old timer
Not tried it yet mate as ive still got to fit the EWS under the dash but cant open the doors wide enough without banging them on the wall so will roll it back down the drive a bit too do that.monkey wrote:is running yet Tony ?
Ive put the battery in though and done a ignition key test and all dash lights ok.Does actually try to crank over but the starter is just whizzing round so ill have to see whats going on with that.
Exhaust is done and fitted now.
Rear valance needs opening upa bit more but I purposly cut it undersize untill final fit and still needs a gearbox mount fitting.
Waiting on output shafts for the diff which will hopefully be Monday.
Ran the polisher over one of my wheels as they are looking terrible after the winter weather.
Still not perfect(I havent got the patience really) but much better than before.
Bastard is ill have to do the other 3 now
Awesome progress in a short space of time.
Exhaust bling
Jozi
I need you here Eko, my touring would be finished by now
Good progress
Liking the exhaust system to.
Cook318IS
That exhaust is the absolute shiz!
