E28 Flywheel Bolts and M30 Clutch Slave
Post Sun Apr 03, 2011 7:32 pm
Looking at getting some new one's but on bmwfans it say's that they are NLA :(
http://bmwfans.info/parts/catalog/E28/S ... _flywheel/
Are the E34 one's the same or what else can I use?
Also, is it best to use a M30 clutch slave? ECP one good enough to do the job?
http://www.eurocarparts.com/ecp/c/BMW_5 ... 6d197&CSCY
TIA
shedrool83
Post Sun Apr 03, 2011 7:54 pm
http://www.realoem.com/bmw/partxref.do? ... +1+717+840
They seem to be the same as alot of models
Post Sun Apr 03, 2011 8:03 pm
All NLA.
shedrool83
Post Sun Apr 03, 2011 9:25 pm
Order them from bminiparts they have 51 of them.
http://www.bmminiparts.co.uk/PartDetail ... 517BCE7F07
Post Sun Apr 03, 2011 11:08 pm
Nice one, thanks for the link, i'll get them ordered :D
Any ideas on the clutch slave cylinder? :)
Bristol_Jer
Post Sun Apr 03, 2011 11:09 pm
I just reused mine, with a good dab of threadlock. Have always done this when rebuilding engines, most people usually do that I know of
leeparkes
Post Sun Apr 03, 2011 11:15 pm
Bristol_Jer wrote:I just reused mine, with a good dab of threadlock. Have always done this when rebuilding engines, most people usually do that I know of
Me too :)
Even Yoda agrees... if its good enough for Dan its good enough for me.
http://www.e30zone.net/modules.php?name ... ight=bolts
Post Sun Apr 03, 2011 11:25 pm
I'll just be flash and buy some new one's as they not that expensive :P
Post Mon Apr 04, 2011 11:19 pm
Bump for second question :)
leeparkes
Post Mon Apr 04, 2011 11:30 pm
Im using the M20 one with no issue's.
Post Mon Apr 04, 2011 11:50 pm
So am I, but me thinks my Master is on it's way out 8O
Post Mon Apr 04, 2011 11:57 pm
Saves me a few quid then :D
The Master on mine looks pretty new, not a big job to change I would of though anyway.
Cypriotgeeza
Post Tue Apr 05, 2011 2:45 pm
i changed my master cylinder when i had them clutch problems :-x took the best part of 15mins to do..not a hard job at all!
Also every mechanic i knows re-uses the flywheel bolts, after a good wire-wheeling then a healthy dab of loctite n bobs your uncle and patsy's your auntie winkeye
Check my M30 build threads:
New Daily : viewtopic.php?f=34&t=285452
Bristol_Jer
Post Tue Apr 05, 2011 9:58 pm
When I looked on the parts list on BMWfans, it gave the M30 slave cylinder as being the same as an e30 318iS, but not as an M20 one?
Post Tue Apr 05, 2011 10:03 pm
Maybe they are all interchangeable :?
Have you fitted an M30 one?
Bristol_Jer
Post Tue Apr 05, 2011 10:20 pm
Not yet Imy, I was planning to though, it's on my ever growing shopping list!
Post Tue Apr 05, 2011 10:26 pm
Ah okay, my shopping list is huge and expensive this month :cry:
Bristol_Jer
Post Tue Apr 05, 2011 10:46 pm
ImysE30 wrote:Ah okay, my shopping list is huge and expensive this month :cry:
I know the feeling mate! :(
Post Tue Apr 05, 2011 10:56 pm
But I keep saying to myself, it'll all be worth it :D
chu346
Post Sat Apr 09, 2011 9:56 pm
What are the torque settings for these bolts?
