anybody know the weight of a large case diff?
325isporttech1
Id take a guess at 35kg
325isporttech1
leeparkes
Get on some bathroom scales and record your weight, get on the scales again with the diff in your arms and the difference in weight is how heavy the diff is (ish)
Edit, id say its 35-40kg
gareth
You're looking at 35-40kg for a 188mm medium (e30 large) case diff. a 750i will have a 210mm large case diff, bigger than anything fitted to a E30. It's got to be 50kg at least.
They look like they're off a truck!
universal
or just put the diff on the scales!!!!!leeparkes wrote:Get on some bathroom scales and record your weight, get on the scales again with the diff in your arms and the difference in weight is how heavy the diff is (ish)
glenn
- Engine Transplant Services
i'm almost sure a medium case diff is around 40kg, so i'd guess a large case is closer to 50kg.
leeparkes
Have you ever seen the size of one of these, you will be lucky to see the dial.universal wrote:or just put the diff on the scales!!!!!leeparkes wrote:Get on some bathroom scales and record your weight, get on the scales again with the diff in your arms and the difference in weight is how heavy the diff is (ish)
325isporttech1
universal
so how would you see the dial with it in your arms? if you could carry it that far!!leeparkes wrote:Have you ever seen the size of one of these, you will be lucky to see the dial.universal wrote:or just put the diff on the scales!!!!!leeparkes wrote:Get on some bathroom scales and record your weight, get on the scales again with the diff in your arms and the difference in weight is how heavy the diff is (ish)
leeparkes
All in the ETK! Assuming it's an ex E32 diff, then it's 46.64 kg.
universal
ok! did'nt think of that. what with it being too big to see the dial without a person holding itleeparkes wrote:lean forward.
325isporttech1
