E36 Compact Compact 328i ti M sport
leeparkes
Post Fri Jul 16, 2010 11:42 pm
Is it just the crank that needs to be swaped over to an M50 block? is the rest the same, ie pistons rods head etc..
What are M50's like compared to M52's performance wise, is there much in it?
town325i
Post Sat Jul 17, 2010 1:41 pm
leeparkes wrote:Is it just the crank that needs to be swaped over to an M50 block? is the rest the same, ie pistons rods head etc..
Now you have driven the M52 all the M50 will do is dissapoint you i feel as you can tell the difference sitting in the passenger seat how much quiker the M52b28 is of the M50b25
Post Sat Jul 17, 2010 2:11 pm
Crank, rods and pistons are different, the bores will need fettling also as the stroke is longer, new rings are a must, head gasket/bolts, rod bolts, oil seals and skim on the head while its off, you will also need timing cover gaskets and possibly crank oil seals, its a good opportunity to fit a new chain/guide. Thats about £400 worth of parts, another M52 lump is probably the easiest/most cost effective way to go.
leeparkes
Post Sat Jul 17, 2010 4:11 pm
DanThe wrote:another M52 lump is probably the easiest/most cost effective way to go.
Thats the plan but have you seen how much some nutters want for bare engines :mad:
Im going to look at a donor car tomorrow morning so fingers crossed
leeparkes
Post Sat Jul 17, 2010 11:30 pm
While searching for a donor ive come across this shit heap :chuckle:
One for the bruvs
http://www.autotrader.co.uk/classified/ ... ?logcode=p
8O
Barx325i
Post Sun Jul 18, 2010 3:14 am
niiiiice
Post Mon Jul 19, 2010 3:09 pm
If it hasn't overheated dude the headgasket should be do-able..
Post Mon Jul 19, 2010 3:10 pm
*My 328i got warm briefly when the water pump went.. That was fine
town325i
Post Mon Jul 19, 2010 10:04 pm
ull the head off you havnt got nothing to loose really in trying
leeparkes
Post Mon Jul 19, 2010 11:06 pm
Its too much of a risk and a good chance ill be throwing money down the drain trying to fix it so a new lump is in order.
I will remove the head though to see whats caused it as im curious myself.
town325i
Post Mon Jul 19, 2010 11:11 pm
Why though all you will waste is the gasket if the threads pull and whats that £20 head skim and pressure test is around £50 and that wont go to waste as a spare for an iron block m50b28
town325i
Post Tue Jul 27, 2010 10:00 am
Have you took the head off this yet?
leeparkes
Post Tue Jul 27, 2010 2:41 pm
No, I havent touched it yet
Post Tue Jul 27, 2010 2:46 pm
Lee, you know what you need in that bay S... winkeye
leeparkes
Post Tue Jul 27, 2010 2:52 pm
A guy near me has an S50 compact and its a proper weapon :twisted:
Post Tue Jul 27, 2010 2:59 pm
Do it!!!!
Then it'd be a proper weapon with a cage and stripped out interior :twisted: :twisted:
Barx325i
Post Tue Jul 27, 2010 8:59 pm
balls, leave the interior, and the 4.1 diff :)
leeparkes
Post Thu Aug 05, 2010 5:06 pm
*Update*
New lump arrived today :D
Cost me just shy of 500 sheets delivered, Its another steel liner block (98 ) and its supposed to be a very good lump in fine fettle, brought from a well known trader on e36coupe.
It also has one of those Alpina blokes M50 manifolds on it and BBTB 8) iirc he charges about 300 quid for these (could be more with the TB) :mad:
Im hoping to get this in over the weekend
Whoop whoop :rock:
snakebrain
Post Thu Aug 05, 2010 6:56 pm
Glutton for punishment! Hope you've better luck with this one... :D
toby
Post Fri Aug 06, 2010 9:25 am
That's a bargain price if it's a reliable engine with all those toys attached, good stuff. You could always use the lawnmower engine, that looks tasty.
Post Fri Aug 06, 2010 12:17 pm
Hope it's a good'en :D
Dezzy
CR24v it's a lifestyle
Post Fri Aug 06, 2010 12:18 pm
Fare play for sticking with it. They look like some tasty mods too. Should be cracking.
zaust
Zone day release
Post Fri Aug 06, 2010 12:27 pm
Nice one, Should go really well with new donk in it, bet you can't wait.
M30 Tech 1 Touring on gas.
leeparkes
Post Fri Aug 06, 2010 3:55 pm
Cheers lads!
Lets hope i have no trouble with this one.
Post Fri Aug 06, 2010 3:58 pm
Fingers crossed for you Lee :cool:
leeparkes
Post Fri Aug 06, 2010 6:07 pm
Cheers!
What ive noticed with these lumps though is how light they are, i managed on my own to wriggle it off the pallet onto my trolley with ease 8)
leeparkes
Post Fri Aug 06, 2010 10:55 pm
leeparkes wrote:It also has one of those Alpina blokes M50 manifolds on it and BBTB 8) iirc he charges about 300 quid for these (could be more with the TB) :mad:
Found out earlier he charges £410 for this set up (delivered) 8O its a neat job but not enough to warrant £400 :mad:
Post Fri Aug 06, 2010 11:02 pm
Very late M52 that is!
Nice to see you have the M52 throttle Lee, im under the impression they give better response 8)
I take it you got the ECU/EWS with this engine?
Dezzy
Post Fri Aug 06, 2010 11:03 pm
£400 must = 100 bhp at least. You got yourself 310bhp there mate. M3 power :cool:
As long as the motor is genuine your laughing at that money.
Dezzy
Post Fri Aug 06, 2010 11:05 pm
DanThe wrote:Very late M52 that is!
:wave:
leeparkes
Post Fri Aug 06, 2010 11:16 pm
DanThe wrote:I take it you got the ECU/EWS with this engine?
No, the guy wanted an extra £100 for the ECU/EWS :?
The plan is to run it on my set up. Will this be fine? the engine is a late 98
You got me flapping now :)
Post Fri Aug 06, 2010 11:20 pm
Wont work mate, your new engine has a rear crank sensor....
leeparkes
Post Fri Aug 06, 2010 11:24 pm
DanThe wrote:Wont work mate, your new engine has a rear crank sensor....
You are f*ckin jokin
I did notice a plug where the tab sits, can i make it run with my set up or do i need the later ECU, will it be EWS3? build date is oct98
:cry:
Andyboy
Alpina Colada
Post Sat Aug 07, 2010 12:56 pm
You could put your entire engine loom and front pulley on the new engine. What you have is a 99-2000 Coupe/Touring/Convertible engine which is a hybrid of an M52 and an M52TU.
leeparkes
Post Tue Aug 10, 2010 7:18 pm
Well im now back on track :)
After consulting with Dan i had two choices to get the engine running right, i could swap the loom over with the front pulley and all the sensors or get the ECU from the engine im putting in.
Quick text to the bloke i got the engine off and £50 later i had this lot delivered today :D
Im so glad its EWS2 so its a plug and play affair!
