aeriel
- lawriejones
How easy/hard is it to remove an old electric aeriel and replace it with another?
- lawriejones
cool, thats what I like to hear.
- **BANNED**
Pull the boot trim out by the aerial and carefully examine the connectors,then when you spend your hard earned,do the same!
This way,you stand at least a sporting chance of this being a simple,plug in job.
Youth is wasted on the young.
Topblag
If it's not going up/down properly and you can hear the motor running when you switch the car on (get a friend to help), I've used some penetrating fluid and given the aerial a helping hand to go up and down and that's solved the issue. If that doesn't work, remove the aerial and open it up (screws only) - have a look at the plastic winding mechanism inside and make it's properly wound when the aerial is down, they can be fixed with more grease on the loop with the plastic teeth.
Unless it's been stuck solid for years, most can be repaired in my experience.
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
town325i
Tbh for all that messing about you can get a black aerial from euro for £30 and a chrome one for around £20 is it really worth messing about?Topblag wrote:If it's not going up/down properly and you can hear the motor running when you switch the car on (get a friend to help), I've used some penetrating fluid and given the aerial a helping hand to go up and down and that's solved the issue. If that doesn't work, remove the aerial and open it up (screws only) - have a look at the plastic winding mechanism inside and make it's properly wound when the aerial is down, they can be fixed with more grease on the loop with the plastic teeth.
http://www.eurocarparts.com/ecp/c/BMW_3 ... d6232&AERL
not an expensive item at all. was surprised my self when I seen the price
- lawriejones
Cheers jbh.
Gonna get one tomorrow.
- lawriejones
Thanks for the info.town325i wrote:Tbh for all that messing about you can get a black aerial from euro for £30 and a chrome one for around £20 is it really worth messing about?Topblag wrote:If it's not going up/down properly and you can hear the motor running when you switch the car on (get a friend to help), I've used some penetrating fluid and given the aerial a helping hand to go up and down and that's solved the issue. If that doesn't work, remove the aerial and open it up (screws only) - have a look at the plastic winding mechanism inside and make it's properly wound when the aerial is down, they can be fixed with more grease on the loop with the plastic teeth.
What happened was, I fitted a new radio, aand the aerial went up, but decided that was it and it never retracted again. I can hear the motor but nothing is happening. I may just replace it and try to repair my one to keep as a spare.
Topblag
Did you miss that my location is Edinburgh, I've lost sleep over losing a £1 coin before !!town325i wrote:Tbh for all that messing about you can get a black aerial from euro for £30 and a chrome one for around £20 is it really worth messing about?Topblag wrote:If it's not going up/down properly and you can hear the motor running when you switch the car on (get a friend to help), I've used some penetrating fluid and given the aerial a helping hand to go up and down and that's solved the issue. If that doesn't work, remove the aerial and open it up (screws only) - have a look at the plastic winding mechanism inside and make it's properly wound when the aerial is down, they can be fixed with more grease on the loop with the plastic teeth.
dapperdan8001
Topblag wrote:Did you miss that my location is Edinburgh, I've lost sleep over losing a £1 coin before !!town325i wrote:Tbh for all that messing about you can get a black aerial from euro for £30 and a chrome one for around £20 is it really worth messing about?Topblag wrote:If it's not going up/down properly and you can hear the motor running when you switch the car on (get a friend to help), I've used some penetrating fluid and given the aerial a helping hand to go up and down and that's solved the issue. If that doesn't work, remove the aerial and open it up (screws only) - have a look at the plastic winding mechanism inside and make it's properly wound when the aerial is down, they can be fixed with more grease on the loop with the plastic teeth.
- lawriejones
All done.
Got a nice black one from Euro car parts £37 incl VAT. Fitted and working a treat.
Cheers for the knowledge fellas.
Topblag
I could've fixed it for 37p.
Nice work fella.
Nice work fella.
