The outcome of my meeting- E30 M3 M30 Turbo Cabby rep
Post Tue Mar 16, 2010 8:46 pm
bss325i wrote:
Rav335uk wrote:
bss325i wrote:I personally would not put 400BHP through a cabrio.
I would :twisted:
You going to seam weld the shell then?
:D Nope
Post Tue Mar 16, 2010 9:02 pm
Rav335uk wrote:
bss325i wrote:
Rav335uk wrote: I would :twisted:
:D Nope
Have you ever seen what happens when you jack a saloon shell up? Cab's are alot worse!
Post Tue Mar 16, 2010 9:04 pm
bss325i wrote:
Rav335uk wrote:
bss325i wrote: You going to seam weld the shell then?
:D Nope
you should have seen when i jacked my old 84 rotten turd up you struggled to open the doors for the thing twisting lol :mad:
kingcruizer
Post Tue Mar 16, 2010 9:10 pm
im running 324bhp through mine. everything is uprated and its fine. does pull a slight wheely when booting it around corners though. winkeye :cool:
"BEFORE I DIE, I WANT TO OWN A CAR WITH AN ENGINE THAT STICKS OUT OF THE BONNET"
Post Tue Mar 16, 2010 9:12 pm
Alex wrote:
bss325i wrote:
Rav335uk wrote: :D Nope
That must be fecked.
When I jack mine up, I can open the doors no probs, one thing I know is that my cab shell is solid, very minimal rust, and thats surface rust.
And I'm sure that Kingcruizer is running Big BHP through his Cab.
Post Tue Mar 16, 2010 9:22 pm
Rav335uk wrote:
Alex wrote:
bss325i wrote: Have you ever seen what happens when you jack a saloon shell up? Cab's are alot worse!
it doesnt look too bad in the pics, but when it was fragged/smashed up rolled on roof etc the rot was unbelivable. i could put a screwdriver through various parts of the floor, it had rusty scuttle (on a pre facelift 8O ) rusty front valance, rust bubbles on roof, sunroof tray had rotten away at the front, bulkhead rot, arches were rusty, from the rear arch going to the front door i managed to knock enought rusty out to stick my hand inside the car, rotten around towing eye, rot as you opened the door starting in door shuts, inner arches wernt bad but not the best. there was no single panel that didnt need welding, most suspension would have been fecked too, rot behind the grills under windscreen pissing water in, Water came from every corner of the car :mad:
Post Tue Mar 16, 2010 9:38 pm
All e30 shells flex, even the rot free ones as they are not a very riggid design.
Putting serious torque through a standard cabrio shell will flex it to the point of slowly opening up the seam sealer which will let moisture in which will cause rot.
That is just the begining of the problem as serious torque will twist the shell and start to throw alignment out.
Even a standard saloon shell with 400lbft+ will end up with stress fractures. A roll cage and seam welding will prevent this.
Post Tue Mar 16, 2010 9:44 pm
Common weak points are front strut turrets and diff mount
There are not many cars out there that do not flex, even my chromie flexes slightly when on the 2 post lift and that is 100% rust free
Post Tue Mar 16, 2010 10:02 pm
DanThe wrote:Common weak points are front strut turrets and diff mount
On Alpina E30's, the front turret seams were prone to cracking due to the stiffness of the suspension.
spook
League two here we come !!!
Post Tue Mar 16, 2010 10:19 pm
bss325i wrote:All e30 shells flex, even the rot free ones as they are not a very riggid design.
A pair of 15 quid hot tuning strut braces will sort this out Imy winkeye
Post Wed Mar 17, 2010 9:59 am
initial_g wrote:oooh nooo xs turbo!!! i used eat those at a rate of one per 2000 miles dont go above 5-6 psi on that turb m8! looking good anyway m8y il pop down and take alook dude :cool:
Where you been hiding dude? :P No wonder you went back to n/a then :mad: How's the track car?
I'm not going mad power, a cab's for cruising not racing/tracking :D
300bhp would do me fine :cool:
Spook - Hottuning braces been ordered winkeye :mad:
chris_335
Post Tue Mar 30, 2010 11:39 pm
engine in
plates off
and vids up
Post Wed Mar 31, 2010 12:17 am
Dont muscle cars crack in the bulkhead/inner wing area because of the torque.
Post Wed Mar 31, 2010 11:42 am
I'm not going for mad power so it should be okay, watch this space soon winkeye
Post Thu Jul 15, 2010 9:18 pm
Any updates? Or are you going to unveil it once its completely finished.
Post Thu Jul 15, 2010 9:22 pm
Got a new cabby (sneak pic to the left winkeye ) so that's taking up most of my time now, got to rebuild it back up from scratch otherwise the engine would be in by now :(
I'm hoping a month or 2 before it's all finished, Santa Pod is the deadline :D
Post Thu Jul 15, 2010 9:38 pm
Sneak preview then??
Steve
Post Thu Jul 15, 2010 9:40 pm
Come on then Imy ! we need more pics :D
webmaster@e30zone.net
Post Thu Jul 15, 2010 9:43 pm
In due time Steve :D
Rav - Look at my avatar pic winkeye
Post Thu Jul 15, 2010 9:44 pm
M3 innit
Ollie_bwoii
Post Thu Jul 15, 2010 9:52 pm
Alex wrote:M3 rep innit
That's it.
Post Thu Jul 15, 2010 9:54 pm
ImysE30 wrote:In due time Steve :D
Seen that one, a bigger pic of that would be better.
Post Thu Jul 15, 2010 9:56 pm
That's it.
Done the proper way :wink:
Rav - You'll just have to wait just a lil bit longer :D
Steve
Post Thu Jul 15, 2010 9:59 pm
ImysE30 wrote:
That's it.
Good for you Imy, don't keep us waiting too long :D
Post Thu Jul 15, 2010 10:02 pm
Steve wrote:
ImysE30 wrote:
Ollie_bwoii wrote: That's it.
Cheers Steve, i'm hoping to create a one off eye catcher, got to show something after all the 'talk' :P :D
Still got loads to do, weather isn't helping :roll: :(
Mayze
Post Thu Jul 15, 2010 10:05 pm
Are you changing the color I seem to recall you saying you were going for something special?
looking forward to seeing the end result,
johnt0709
Good Imy take your time with it
Phase I - Bodywork Complete
http://www.e30zone.net/modules.php?name ... by+restore
Phase II - 2.8 stroker- Complete
Project II - 325 Motorsport Cabriolet Restoration.
Post Thu Jul 15, 2010 10:07 pm
No, it's white, nice and shiny 8)
E30 M3 Cabby rep with E30 M3 suspension and a M30 Turbo under the bonnet :D
Mayze
Post Thu Jul 15, 2010 10:10 pm
White m3's look the dogs keep it clean and it will look fantastic.
Post Thu Jul 15, 2010 10:11 pm
I'm hoping so, will be stored in a heated garage when not in use (that'll be most of the time then :P )
Post Thu Jul 15, 2010 10:17 pm
Is it on E34 540i wheels?
Post Thu Jul 15, 2010 10:19 pm
Not sure what they are, it's got odd wheels on it now, just temporary so i can move it about.
Going to get some nice deep dish wheels 8)
bmw-mad
Post Thu Jul 15, 2010 10:25 pm
Like the sneaky pic Imy winkeye
Post Thu Jul 15, 2010 10:29 pm
Location looks familiar :o:
Mayze
there was a guy in the new members section who had an e34 with hartage wheels on it but being an e34 they were dished they would look v :cool: on your car.
