The 3.2 Alpina Powered Chromie
Dezzy
CR24v it's a lifestyle
Post Sat Mar 06, 2010 12:16 am
town325i wrote:
Jozi wrote:Are the bigger brakes also a WMS item?
They are off another BMW just cant remember which one i think a 540 of some description
As far as I am aware E34 540 brembo calipers withcustom brackets and 300mm discs.
Post Sat Mar 06, 2010 12:20 am
540 calipers and 312mm TT disks, its fooking tight! 2mm max between the caliper and wheel, but the gap will get bigger as the pad wears which is good.
Im just rubbing the zinc off at the moment and getting them bedded in nice, needs my 750 master cylinder fitted to bring the pedal up but will get the rears on first.
Its seems to have taken ages to get this far, I ended up having the calipers sand blasted and zinc plated before fitting new seals etc
Disks have also been zinc plated to keep the rust at bay :D
town325i
Post Sat Mar 06, 2010 12:22 am
Are those the TT discs you had in the footwell of your 4 door when you took me out in that the other year
Dezzy
Post Sat Mar 06, 2010 12:23 am
Fooking hell mate no wonder it's tight!
Measure behind your spokes for me please. I may need my WMS's spaced out as the rules state. winkeye
Post Sat Mar 06, 2010 12:27 am
town325i wrote:Are those the TT discs you had in the footwell of your 4 door when you took me out in that the other year
No I sold those to Bob as I changed my mind and bought the 4 pots, but since fitting the 16 inch Hartges I needed bigger brakes to fill the gap as per the CR24V rule book states :)
They are the same though, only bad thing is these weigh at least twice as much as the WMS setup, but for a road car its not a big issue 8)
Dezzy
Post Sat Mar 06, 2010 12:29 am
No I sold those to Bob as I changed my mind and bought the 4 pots, but since fitting the 16 inch Hartges I needed bigger brakes to fill the gap as per the CR24V rule book states :)8)
Ha ha :cool:
keri-WMS
Post Sat Mar 06, 2010 9:07 am
DanThe wrote:They are the same though, only bad thing is these weigh at least twice as much as the WMS setup, but for a road car its not a big issue 8)
So did you swap the WMS stuff onto another (track?) car? You know I can upgrade the 280mm kits to 300mm if people want (that's the idea of the modular stuff!)? winkeye
Dezzy wrote:Measure behind your spokes for me please. I may need my WMS's spaced out as the rules state. winkeye
Here's the WMS 298.5x24 template behind Bob_S's 16" Hartge's, he reckons a 3mm spacer is needed, to be confirmed!
(Cheers Bob! :thumb: )
Dezzy
Post Sat Mar 06, 2010 9:42 am
Cheers keri. I need to print one out and check but till hubs and ofset is sorted I don't know where I am. You will be my first port of call mate :thumb:
Sorry for highjack Dan :D
Post Sat Mar 06, 2010 9:45 am
Yep the 4 pots are now on the track slag, no need to go any bigger for that as tyres/wheels are better priced in 15 inch
I would have gone for some 4 pots again if I thought I needed the extra performance, but for a road car these single piston jobbies should be fine 8)
keri-WMS
Post Sat Mar 06, 2010 12:03 pm
DanThe wrote:Yep the 4 pots are now on the track slag, no need to go any bigger for that as tyres/wheels are better priced in 15 inch
Gotcha! :D
Dezzy
Post Tue May 11, 2010 6:20 pm
Rear Disc's?
Engine?
Suspension?
You done anything yet?
We need a 3.2 24v Chromie as the flagship CR24v car! 8)
Post Tue May 11, 2010 6:43 pm
Not really, engine/box is nearly ready to go in, rear calipers have been handed over for zinc plating and its had a fresh MOT today
Might have some progress to report in a few weeks time 8)
town325i
Post Tue May 11, 2010 9:11 pm
Baggsy the first shot gun ride in the 3.2 :D
Post Mon May 17, 2010 10:42 pm
The chromie went up in the air on Saturday, here are a few pics to wet your appetites
I just hope it works :mad:
Dezzy
Post Mon May 17, 2010 11:01 pm
I spy a Alpina inlet :cool:
I know you said it was tight at the slave but fooking hell. You need an inspection plate.
I need to see that lump in there. 8O
The_Diddler
Love it up the more door !
Post Mon May 17, 2010 11:18 pm
Tight that Dan 8O , cover up the removed lump will yer winkeye winkeye, dont think it will be long now before it sits in its new home :woohoo: :woohoo:
Post Tue May 25, 2010 7:13 pm
This is how I left the car tonight, (click for bigger pic)
Been out for a quick test run, about 6 miles, feels like its got a missfire at certain revs but its not using the right ECU at the moment, got it running on a late 328i ecu while I sort out the S52 brain.
Throttle needs adjusting as its not opening fully and it needs some fresh go-go juice so will see whats what tomorrow after a visit to mr Shell and some diagnostics
The E46 6 speed box ive bodged on the back is working well, the gear ratios are as expected and feel like the ratios I was told from ZF Transmissions, gear change is a bit notchy so will get some thinner oil to go in, should be MTF LT2 but not at that price!
70mph is just under 2500rpm :cool:
Got more pics on my puter, will get them sorted when it decides to turn on :?
Post Tue May 25, 2010 7:15 pm
:cool: :cool: :cool: :cool:
Dezzy
Post Tue May 25, 2010 7:30 pm
Nice work brother.
That engine cover just won't do! :D
Post Tue May 25, 2010 8:02 pm
What is wrong with the cover? Its OEM you know
Dezzy
Post Tue May 25, 2010 8:08 pm
DanThe wrote:What is wrong with the cover? Its OEM you know
You homo. winkeye
Post Tue May 25, 2010 9:11 pm
Very nice Dan, looks at home in there :cool: :cool:
Bringing it to the meet? :D
town325i
Post Tue May 25, 2010 9:16 pm
Dan if you plan on going to the meet in this can you pick me up i dont think i can bare the shame of the golf :D
Post Tue May 25, 2010 9:22 pm
town325i wrote:Dan if you plan on going to the meet in this can you pick me up i dont think i can bare the shame of the golf :D
Bring the Golf, it's German :mad:
town325i
Post Tue May 25, 2010 9:39 pm
You havnt seen it :D
Ollie_bwoii
Please bring it Town, after all yellow is mellow. :wink:
Post Tue May 25, 2010 9:40 pm
How many doors? Surely not more than 3 8O
town325i
Rav335uk wrote:How many doors? Surely not more than 3 8O
No deffinatly not ok i will bring the golf :D
Post Tue May 25, 2010 9:42 pm
No need to be embarrassed, at least it has the correcxt amount of doors :cool:
Post Tue May 25, 2010 9:52 pm
If I get it running better then maybe yes, dont want to be doing too many miles if its over fueling
Anybody got a pdf of an S52B32 ECU wiring diagram?
E30Gheko
Post Wed May 26, 2010 12:09 am
Impressive as ever Dan. Very nice indeed mate. 8) 8)
Post Wed May 26, 2010 7:25 am
Nice job Dan - looking forward to seeing this :D
Daf318is
Post Wed May 26, 2010 8:31 am
Epic!
I may be travelling south next weekend - if you're around I may pop in for a nosey as I go past :D
Now driving an E46 320D touring :(, but it get's worse..... the new project is going to be Ford powered!
Post Wed May 26, 2010 6:04 pm
Let know when boyo and I will try and be available 8)
Post Wed May 26, 2010 6:05 pm
Looks right at home in there mate, looks bloody fantastic.
I salute you sir :)
