help spraying my grills satin black ?
k13
Post Sun Nov 30, 2008 1:23 pm
ive used sand paper to key the grills, then i used one layer of grey primer, then i waited for 45mins and sprayed 2 coats of satin black. however im seeing the black paint fading away in to the primer and its got like grey patches...what shall i do as i dont want to waste any paint, should i keep spraying more coats of satin black for the grey patches to go away ???
help.
leeparkes
Post Sun Nov 30, 2008 1:50 pm
once the primer was applied did you wet & dry it before painting satin black
k13
Post Sun Nov 30, 2008 6:14 pm
nope i didnt but i thought the primer acts as a key for the basecoat so i wouldnt need to wet and dry it. ive done about 3 coats on it so far and its looking pretty good. will apply maybe 2 more coats then call it a day. to get that extra shine what can i add to it ?
leeparkes
Post Sun Nov 30, 2008 6:18 pm
wet & drying the primer will just give it a smoother finish,
it will probably only need another 2 coats,just give it time between coats,
k13
Post Mon Dec 01, 2008 11:06 am
im not really feeling the satin black look on the grill as i was hoping for a big shine, shouldve used gloss paint i think, can i spray gloss black over the satin or will i need to sand the satin paint down abit ?
neamem
Post Mon Dec 01, 2008 1:54 pm
let it dry off for a few days. stick it in the airing cupboard to speed it up ;) then sand down with 3000 grit wet and dry and a couple of light coats with gloss should do the trick.
Dresden
Post Sat Dec 06, 2008 3:37 am
wait wait...so you went for satin because you wanted shine?
Maybe it's only in the states, but we like satin because it's not shiny, more of an aggressive appearance. I think it relates to the stealth bomber look.
sam325is
Post Mon Dec 08, 2008 7:00 pm
Use adhesion promoter
FreddieS
Post Tue Dec 09, 2008 5:40 pm
Dresden wrote:wait wait...so you went for satin because you wanted shine?
Stealth cars are the way forward :D
Really need to spray the grill of my BMW satin as it looks crap being patchy grey plastic!
tinnaM42
Post Tue Jan 13, 2009 7:17 pm
that metro is mint!
