m30 swap m30 or m10 gearbox?
whipsey
Post Mon Sep 29, 2008 7:57 pm
quick question i've got both an m30 and m10 maual gearboxs have read in a post that if the m10 box is used i can use an m20b20 prop with no modifications
FormerMember
Post Mon Sep 29, 2008 8:06 pm
Use M30 gearbox, box behind M10 can't take the torque for long.
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
whipsey
Post Mon Sep 29, 2008 8:09 pm
what kind of power etc can the m10 box handle?
GrindCulture
Post Mon Sep 29, 2008 9:27 pm
There's a guy in the states (goes by the username of Good and Tight on various forums) who was putting down near to 360bhp from a stock M10, with a stock gearbox and driveline, running on about 30psi of boost. So by the looks of that, a lot!
Not in E30s any more :(
jaffro
Post Mon Sep 29, 2008 9:30 pm
depends how you intend to drive it. why not just change output flange on m30 box for m20 flange then use a m20 2.5 prop. :P
whipsey
Post Mon Sep 29, 2008 9:33 pm
will it fit jaffro? i have a spare m20b20 and b25 prop sitting here would prefer to use the m30 box as i have a new clutch for it would an auto have a different prop?
jaffro
Post Mon Sep 29, 2008 9:35 pm
yeh me a ric325i have just done the very thing a its perfect a saves the hassle of m3 or custom props and the cost
whipsey
Post Mon Sep 29, 2008 9:50 pm
so are the auto and manual props a different size?
jaffro
Post Mon Sep 29, 2008 9:53 pm
yeh its manual 325 prop you need. :P
whipsey
Post Mon Sep 29, 2008 9:55 pm
damn i've got an auto 325 prop and a manual 320 one
jaffro
Post Mon Sep 29, 2008 9:58 pm
somebody must have just a front part of manual 2.5 prop they could donate to you thats near by. i gave my last 1 away 2 :cry:
whipsey
Post Mon Sep 29, 2008 10:22 pm
do you know the size of the props needed i'll have a look at what i have i think there is an m10 prop here as well
whipsey
Post Tue Sep 30, 2008 7:03 pm
jaffro wrote:output flange on m30 box for m20 flange then use a m20 2.5 prop. :P
is that the rubber part attached to the gearbox?
jaffro
Post Wed Oct 01, 2008 8:20 am
yeh mate its attached to the output flange with 3 bolts.
whipsey
Post Wed Oct 01, 2008 10:26 am
woohoo got that off will swap with the m30 one now will just need to get a 325 manual prop
ric325i
Post Wed Oct 01, 2008 12:04 pm
