M20B25 valve guides
spewy555
Post Wed Feb 01, 2012 2:22 pm
Is there anyone in the UK that keeps valve guides in stock for the M20?
Born to loose, live to win
ross2009
Post Wed Feb 01, 2012 3:09 pm
any decent engine shop should be able to get them my local guy got mine easy
Turbo M20
v8 project 6.0 twin turbo
SilverShadow
Hartge Crew
Post Mon Feb 06, 2012 7:23 pm
silly questions but why are you replacing the guides?
why not ream them and use larger valves?
ross2009
Post Mon Feb 06, 2012 7:27 pm
the only guides that will need replacing are the exhaust guides as they wear alot more the inlet side should be the same as from factory
Turbo M20
SilverShadow
Hartge Crew
Post Mon Feb 06, 2012 9:48 pm
so the machine shop would just pop the old ones out and replace the new ones - so that you use your current valves?
ross2009
Post Mon Feb 06, 2012 10:00 pm
yeah theres no need to replace the valves they will be fine if its done average milage
but having said that they do ream the new ones to suit which ever valve you use
Turbo M20
spewy555
Post Sun Feb 12, 2012 4:11 pm
It is just the exhaust guides as they are very poor. I have had some made now as everyone that listed them off the shelf had none in stock with no delivery date.
Bloody expensive to change the valves just because the guides are oversize!
ross2009
Post Sun Feb 12, 2012 4:27 pm
I could have got you some from my guy I use :)
Turbo M20
Ant
Retired Team Member
Retired Team Member
Post Sun Feb 12, 2012 7:20 pm
reamed out stock guides with OS ( stem) valves are a no win IMHO
More valve train friction, heavier valve...........
less is defo more :D
ross2009
Post Sun Feb 12, 2012 7:47 pm
spewy555 wrote:It is just the exhaust guides as they are very poor. I have had some made now as everyone that listed them off the shelf had none in stock with no delivery date.
who said anything about oversize valves lol
Turbo M20
