318is timing again !!help!! (pics added)
keggy
Post Fri Apr 28, 2006 8:41 pm
ok guys can ne1 show me where to align these timing marks & how to lock the cams
also does ne1 know how to remove the bottom timing cover
tim_s
Post Fri Apr 28, 2006 8:50 pm
keggy ideally you want the bmw tool for locking the cams, which locks the square bits on the end of the cams. put a straight edge on them and you can make sure they're just about aligned, with the lobes on one pointing towards each other, arrows on sprockets pointing up etc.
2.1 318is, MS, LPG. 200bhp, 175ft/lbs GONE!
Boxster, e46 m3, e36 sport touring and alpina B3 3.0
keggy
Post Sat Apr 29, 2006 10:03 am
wen im in there today ill see if theyll lend me the tools winkeye. how do u removes the bit the crank pulley bolts onto? i need to remove it to take off the bottom cover
E30Mark
Post Sat Apr 29, 2006 10:11 am
keggy wrote:wen im in there today ill see if theyll lend me the tools winkeye. how do u removes the bit the crank pulley bolts onto? i need to remove it to take off the bottom cover
Ideally you unbolt it whilst it's in the car......... you will need to lock up the crankshaft, and get a damn long breaker bar on there, best of luck!
PM for details
keggy
Post Sat Apr 29, 2006 10:18 am
no ive got the pulley off already its wots behind it that i dont know how to remove
stuartgallafant
Post Sun Apr 30, 2006 1:29 pm
are you talking about the front covers?
mk1chopper
Post Sun Apr 30, 2006 10:20 pm
Try this web page, has a run through on what to do, hope it helps
http://www.esatclear.ie/~bpurcell/318istimingchain.html
