M10
Revision as of 08:34, 20 January 2014 by Grrrmachine (talk | contribs)
M10B18 fuel-injected engine
Models
M10B18 1.6 L (1766 cc/97 in³) 89 hp (66 kW) @ 5500 101 ft·lbf (137 N·m) @ 4000 6200 1982-1987
M10B18 1.8 L (1776 cc/109 in³) 105 hp (77 kW) @ 5800 107 ft·lbf (145 N·m) @ 4500 6200 1987
M10B18 9:1
82-88
Ø: 89
KH: 47.1
ÜH: 4.5
GL: 83.6
BO: 22.0 x 58
Stroke: 71
Conrod Length: 135
Volume 1766cc
Piston Shape: M10Pistons.jpg
Timing Chain
Cam
All engines use an 8mm stem.
Valve tappet clearance, inlet and exhaust on a cold engine: 0,20mm
Valve tappet clearance, inlet and exhaust on a warm engine: 0,25mm
Rocker Arms
Breather Hose
Engine Mounts
M10 engine mounts are the standard design of aluminium arms cushioned with rubber mounts. On some models a hydraulic shock absorber was also fitted to provide superior vibration damping.
Carburettor Upgrade
Useful websites
See also
