Engine Swap - M20
Revision as of 19:22, 20 February 2013 by Grrrmachine (talk | contribs)
There's no simpler swap from the possible choice of engines than the mighty M20. While the smallest version was 2.0 litres, its full-fat form is a 2.5 litre version, which is the only one worth having. Around town it gives all the smoothness you'd expect from a straight six, and there's plenty of grunt so you won't be chasing up and down the gears trying to find the right cruising speed. But let her rip, and she'll provide as much tail-happy sliding as you want.
The M20 can be fitted to any E30, no matter whether it started life as an M10, M40 or M42. With the right base vehicle a weekend is enough to get everything bolted in and ready to go. You can even use this guide replace your existing M20 with a bigger version, and in that case the engines can be swapped over in a matter of hours.
This swap is considered the easiest swap because all the parts are standard BMW. There's no need for custom components, and everything you need can be supplied by one donor vehicle. In terms of fabrication, you may need to mount (weld) a few brackets under the bonnet for engine ancillaries and modify the loom a little, but this is specific to the age of your E30. We'll explain that later.
Engine
Parts List
For all swaps, you will need:
  • Full engine with all ancillaries (injectors, AFM, coil, alternator, engine mounts, starter motor and flywheel)
  • Complete engine loom
  • ECU
  • Complete exhaust from manifold to back box
  • M20 Cooling system of radiator, hoses and expansion tank
  • M20 Coding plug for the Instrument cluster
  • A mate on standby. An extra pair of hands can save your life.
  • M20 Gearbox. While the standard M20B25 gearbox is a Getrag 260, it is not uncommon to fit the Getrag 240 gearbox from the 320i for its sportier ratios. Using this box also means its possible to retain your 318i or 316i propshaft. If you use the Getrag 260, you need the shorter propshaft that goes with it. It is possible to use an M40 gearbox, but it will sit at a significant angle, which necessitates customising the gearbox mount and shifter mechanism; not recommended.
  • Differential. While its possible to keep your original diff, you will find that first gear is now useless. All other E30 differentials have a higher ratio than the M20B25 ones, which is great for acceleration but terrible for motorways and wet-weather driving. We highly recommend fitting a medium-case differential designed for a 2.5 engine.
  • propshaft
  • gear shifter linkage
  • rear light switch cable
  • throttle cable
  • coil
  • ECU
While parts suppliers do list differences between B20 and B25 engines, there's no practical difference. A B20 clutch will work fine on a B25 engine.
Prop
Exhaust
Brackets
