M10
Revision as of 11:53, 11 September 2012 by Grrrmachine (talk | contribs)
After the September 1987 facelift the fuel-injected M10 would be known as the 316i, removing the 316 from the model line-up. The 318i was fitted with the new M40 engine which would also power the 316i from September 1988.
Models
M10B18 1.6 L (1766 cc/97 in³) 89 hp (66 kW) @ 5500 101 ft·lbf (137 N·m) @ 4000 6200 1982-1987
M10B18 1.8 L (1776 cc/109 in³) 105 hp (77 kW) @ 5800 107 ft·lbf (145 N·m) @ 4500 6200 1987
Every engine needs its fluids and filters changed regularly. The M10 engine will also needs its timing chain replaced after a certain mileage, but more important is the condition of the chain sprocket. If yours is getting rattly, learn more about changing the timing chain.
Carburettor Upgrade
The Pierburg 2BE carburettor found in 316 models is not considered a particularly good carburettor. Converting to a Weber carburettor will yield more power and more tuning options. Learn more about Weber carburettors.
Useful websites
See also
