M40
| M40B16 | 1.6 L (1596 cc/97 in³) | 75 kW (101 hp) @ 5500 | 143 N·m (105 ft·lbf) @ 4250 | 6200 | 1988 |
| 73 kW (98 hp) @ 5500 | 141 N·m (104 ft·lbf) @ 4250 | 6200 | 1988 | ||
| M40B18 | 1.8 L (1796 cc/109 in³) | 85 kW (114 hp) @ 5500 | 165 N·m (122 ft·lbf) @ 4250 | 6200 | 1987 |
| 83 kW (111 hp) @ 5500 | 162 N·m (119 ft·lbf) @ 4250 | 6200 | 1987 |
Sump Gasket
Piston Head
Piston Rings
Crank Pulley
Despite the three styles of Head, the rocker cover is interchangeable across all M40 engines. It is positioned on 8 studs and fixed with M10 nuts. It has one hole for the Oil Cap, and one port for the breather hose.
Cam
Rocker Arms
Breather Hose
Engine Mounts
Won't Rev Over 5000
To confirm, remove the rocker cover and baffle plate so that you have access to the cam shaft, and run your finger nail over the cam lobes. If you can feel scatches, grooves or other imperfections, the cam is in bad condition.
The only solution is to replace.
