Converting to Motronic 1.3
Revision as of 11:25, 7 June 2012 by Grrrmachine (talk | contribs)
Benefits
From Jetronic From Motronic 1.0 From Motronic 1.1
ECU ECU ECU
Crank Position Sensor & Bracket Crank Position Sensor & Bracket
Toothed crank wheel Toothed crank wheel
Engine bay loom Inc Injector Loom Engine bay loom Inc Injector Loom
Cylinder Identification Sensor Cylinder Identification Sensor
Oil Level Sender Oil Level Sender
Oil Pressure Switch* Oil Pressure Switch*
Distributor cap and rotor arm
Temperature Gauge Sender
Camshaft dust cover
Camshaft rotor adapter
Injectors
Air Flow Meter
  • Oil Pressure Switch is optional as the loom can easily be modified to use the existing switch.
Installation
If converting from Jetronic you will need to follow this guide through all three stages listed below, if you are starting with M1.0 you only need follow the second and third section and to upgrade from M1.1 you can just skip to the last section.
From Jetronic
Camshaft rotor adapter (7) and dust cover (6)
Distributor
Injectors
Air Flow Meter
Temperature Sender
From Motronic 1.0
Here you can see the CPS in position on the front of the block, ready to pick up the signal off the crank pulley. All M20 blocks have the threaded holes ready to fit this.
On the left is the toothed crank pulley you'll need to fit(note the 7th hole which is for the locating pin), then on the right is the PAS pulley that then bolts in place, you can use your existing one.
What wiring does need doing is for instrumental purposes only and is easiest to carry out on the ECU plug end. There are two wires you need to cut on the ECU plug and then connect to the C104 plug which will now be unconnected following the removal of the old loom. The easiest thing to do is cut the matching plug from the old loom and plug it into the loose plug in the car. Then you need to connect pin #1 (Blk/Blu) on the C104 to pin #6 (Blk) on the ECU, the second connection to make is to connect C104 pin #3 (Wht) to ECU pin #32 (Wht/Blk), C104 pin #2 is not used.
Oil Pressure Switch
This is located on the exhaust side of the engine block, this is vital as it's linked to the instrument cluster and if it comes on you want to be turning the engine off ASAP! Jetronic and M1.0 use a spade connector whereas M1.1 and M1.3 use the same type of multipin plug other engine sensors use (although still only using one wire). The function of both types is identical. There are two simple options to get this working, either chop the plug off the new loom and use a spade connector or for the more professional job swap the switches over.
M1.0 oil pressure switch with a spade type connector.
Oil Level Sensor
CID
From Motronic 1.1
