Main article: Clutch
- Put the handbrake on full
- Select 2nd or 3nd gear
Manual
Four-Speed | Five-Speed | |||||
316 | 316 316i 318i | 318iS | 323i Sport | 323i 324td 325e | 325i Sport | |
1st | 3.76 | 3.72 | 3.72 | 3.76 | 3.83 | 3.35 |
2nd | 2.04 | 2.02 | 2.02 | 2.33 | 2.20 | 2.03 |
3rd | 1.32 | 1.32 | 1.61 | 1.32 | 1.40 | 1.36 |
4th | 1.00 | 1.00 | 1.00 | 1.23 | 1.00 | 1.00 |
5th | 0.81 | 0.80 | 1.00 | 0.81 | 0.81 | |
Reverse | 4.10 | 3.45 | 3.71 | 4.10 | 3.46 | 3.20 |
Getrag 242 | Getrag 240 or 242/5 | Getrag 240 | Getrag 245 | Getrag 260 | Getrag 260/5 |
- Getrag 240 - MN or BMV
- Getrag 242 - LF, MD or BMU
- Getrag 242/5 - AY, AW or LG
- Getrag 245 - BJ
- Getrag 260 - NW, ANB or TNW
- Getrag 260/5 - TNN or HM
Automatic
Three-Speed | Four-Speed | ||
316 318i | 320i 323i | 325i | |
1st | 2.48 | 2.73 | 2.48 |
2nd | 1.48 | 1.56 | 1.48 |
3rd | 1.00 | 1.00 | 1.00 |
4th | 0.73 | 0.73 | |
Reverse | 2.09 | 2.09 | 2.09 |
ZF 3 HP 22 | ZF 4 HP 22 |
Selector
Propshaft
Manual | Automatic | |
316 318i | ||
318iS | ||
320i | 1526mm | 1337mm |
323i | 1468mm | 1337mm |
324td 325i | 1483mm | 1327mm |
Guibo
Bearing
Main article: Differentials
Output Flanges
Drive Shafts
Oil Leaks
Sloppy Gearstick
Auto to Manual
Short Shifter
