Converting to Motronic 1.3
Benefits
| ECU | ECU | ECU |
| Crank Position Sensor & Bracket | Crank Position Sensor & Bracket | |
| Toothed crank wheel | Toothed crank wheel | |
| Engine bay loom Inc Injector Loom | Engine bay loom Inc Injector Loom | |
| Cylinder Identification Sensor | Cylinder Identification Sensor | |
| Oil Level Sender | Oil Level Sender | |
| Oil Pressure Switch* | Oil Pressure Switch* | |
| Distributor cap and rotor arm | ||
| Temperature Gauge Sender | ||
| Camshaft dust cover | ||
| Camshaft rotor adapter | ||
| Injectors | ||
| Air Flow Meter |
- Oil Pressure Switch is optional as the loom can easily be modified to use the existing switch.
Installation
If converting from Jetronic you will need to follow this guide through all three stages listed below, if you are starting with M1.0 you only need follow the second and third section and to upgrade from M1.1 you can just skip to the last section.
From Jetronic
Distributor
Injectors
Air Flow Meter
Temperature Sender
From Motronic 1.0
What wiring does need doing is for instrumental purposes only and easiest to carryout on the ECU plug end. There are two wires you need to cut on the ECU plug and then connect to the C104 plug which will now but unconnected following the remocal of the old loom. The easiest thing to do is cut the matching plug from the old loom and plug it into the lose plug in the car. Then you need to connect pin #1 (Blk/Blu) on the C104 to pin #6 (Blk) on the ECU, the second connection to make is to connect C104 pin #3 (Wht) to ECU pin #32 (Wht/Blk), C104 pin #2 is not used.
Oil Pressure Switch
This is located on the exhaust side of the engine block, this is vital as it's linked to the instrument cluster and if it comes on you want to be turning the engine off ASAP! Jetronic and M1.0 use a spade connector whereas M1.1 and M1.3 use the same type of multipin plug other engine sensors use (although still only using one wire). The function of both types is identical. There are two simple options to get this working, either chop the plug off the new loom and use a spade connector or for the more professional job swap the switches over.
Oil Level Sensor
CID
From Motronic 1.1
