Converting to Motronic 1.3
Benefits
From Jetronic | From Motronic 1.0 | From Motronic 1.1 |
Distributor cap and rotor arm | Toothed crank wheel | ECU |
Camshaft rotor adapter | Crank Position Sensor | |
Camshaft dust cover | CPS bracket | |
Injectors and loom | Engine bay loom | |
Air Flow Meter | Cylinder Identification Sensor | |
Oil Level Sender | ||
Temperature Gauge Sender |
Installation
From Jetronic
Distributor
Injectors
Air Flow Meter
Oil Level Sensor
Temperature Sender
From Motronic 1.0
Crank Position Sender
What wiring does need doing is for instrumental purposes only and easiest to carryout on the ECU plug end. There are two wires you need to cut on the ECU plug and then connect to the C104 plug which will now but unconnected following the remocal of the old loom. The easiest thing to do is cut the matching plug from the old loom and plug it into the lose plug in the car. Then you need to connect pin #1 (Blk/Blu) on the C104 to pin #6 (Blk) on the ECU, the second connection to make is to connect C104 pin #3 (Wht) to ECU pin #32 (Wht/Blk), C104 pin #2 is not used.
CID
From Motronic 1.1
