Engine Management
Engine management is pretty much what is says in the tin. It is a system that controls the running of the engine.
Engine management in its simplest form controls the engine via fuelling and ignition timing. The entire E30 range has some form of engine management system, from the most basic carburetted M10, through the various guises on the M20 to the most modern on the M42 with seperate coil packs. Aftermarket systems are also available for those running highly tuned engines allowing the user manual control over multiple settings.
Jetronic
Main artice: L-Jetronic
Jetronic was the first form of engine management fitted to the E30. It comprised of a rudimentary ECU and a variety of analogue sensors dotted around the Drivetrain, and provided the most basic of fuel injection management.
Motronic
Main article: Motronic
Motronic is the trade name given to a range of digital engine-management systems developed by Bosch. This superseded L-Jetronic which was also produced by Bosch but was a more primative analogue system.
Motronic 1.0
This is the first version of Motronic engine management used on fuel injected E30s, this is what is fitted to pre-facelift cars. The obvious things to spot to tell this from M1.1 & M1.3 are the fact this has an ECU with a number ending 073 and that is has 2 pickup sensor attached to the bellhousing instead of a single one on the front of the block.
Motronic 1.1/1.3
Motronic M1.1 and then M1.3 were the most advanced versions used on the E30 8v and 12v engines. This can be found on all facelift cars with M40 and M20. M1.1 and M1.3 can be differentiated by their ECUs.
- Main article: Motronic Engine Management Upgrades & Functions
Motronic 1.7
This is the most modern management system that an E30 left the factory with. It was only fitted to the M42 engined 318iS. This did away with a distributor and coil, the use of individual coilpacks was introduced.
Motronic Fault Codes
- Main article: Motronic Fault Codes
List of ECUs
| 0260 200 005 | Carburettor | 316 | 1982- |
| 0280 000 318 | L-Jetronic | 318i | 1983 - 84 |
| 0280 000 330 | L-Jetronic | 318i | 1984 - 87 |
| 0280 001 301 | L-Jetronic | 320i and 323i | 1982 - 84 |
| 0280 001 309 | L-Jetronic | Later 320i | |
| 0280 001 308 | L-Jetronic | Later 323i | |
| 0280 000 310 | L-Jetronic | Late 323i | |
| 0261 200 172 | Motronic | 320i | 1987 |
| 0261 200 173 | Motronic | 325i Plastic bumper | 9/87 onwards |
| 0261 200 090 | Motronic | Evo II | |
| 0261 200 092 | Motronic | Sport Evo | |
| 0261 200087 | Motronic | 320iS | |
