Main article: Clutch
- Put the handbrake on full
- Select 2nd or 3nd gear
The gearboxes on all cars are bolted to the back of the engine via a bell housing, and are held to the car by a crossmember. While it is possible to remove the gearbox from the car in situ, it is considered much easier to disconnect the Engine and remove both units in one.
Manual
Four-Speed | Five-Speed | |||||
316 | 316 316i 318i | 318iS | 323i Sport | 323i 324td 325e | 325i Sport | |
1st | 3.76 | 3.72 | 3.72 | 3.76 | 3.83 | 3.35 |
2nd | 2.04 | 2.02 | 2.02 | 2.33 | 2.20 | 2.03 |
3rd | 1.32 | 1.32 | 1.61 | 1.32 | 1.40 | 1.36 |
4th | 1.00 | 1.00 | 1.00 | 1.23 | 1.00 | 1.00 |
5th | 0.81 | 0.80 | 1.00 | 0.81 | 0.81 | |
Reverse | 4.10 | 3.45 | 3.71 | 4.10 | 3.46 | 3.20 |
Getrag 242 | Getrag 240 or 242/5 | Getrag 240 | Getrag 245 | Getrag 260 | Getrag 260/5 |
The M42 engine mates up to the same gearbox used in M40 engines, but is not campatible with earlier M10 gearboxes due to the angle of installation, which will cause problems with the shifter and rear gearbox mount. In a similar way, although the M40 and M42 boxes are interchangeable, the input/output shafts are different and so is the propshaft. This means that replacing a 318iS gearbox with the more mundane 318i unit will necessitate a change in prop.
- Getrag 240 - MN or BMV
- Getrag 242 - LF, MD or BMU
- Getrag 242/5 - AY, AW or LG
- Getrag 245 - BJ
- Getrag 260 - NW, ANB or TNW
- Getrag 260/5 - TNN or HM
Automatic
Three-Speed | Four-Speed | ||
316 318i | 320i 323i | 325i | |
1st | 2.48 | 2.73 | 2.48 |
2nd | 1.48 | 1.56 | 1.48 |
3rd | 1.00 | 1.00 | 1.00 |
4th | 0.73 | 0.73 | |
Reverse | 2.09 | 2.09 | 2.09 |
ZF 3 HP 22 | ZF 4 HP 22 |
Selector
Propshaft
Manual | Automatic | |
316 318i | ||
318iS | ||
320i | 1526mm | 1337mm |
323i | 1468mm | 1337mm |
324td 325i | 1483mm | 1327mm |
Guibo
Bearing
Main article: Differentials
Output Flanges
Drive Shafts
Oil Leaks
Sloppy Gearstick
