M5x Looms
Revision as of 12:39, 17 November 2011 by Grrrmachine (talk | contribs)
C101 and X20 engine plugs
M50B25
wiring for an E34 M50B25 into an E30
Pin # C101 Colour Goes to.. on E30 Connect to Pin # M50B25 engine plug
1 blue pin 16 blue plug inst cluster - Charge light 25 blue
2 green/yellow Pin 16 check panel - static oil level 1 blue/white
3
4 brown pin 26 blue plug inst cluster- temp gauge 12 brown/yellow
5 brown/green pin 18 blue plug inst cluster- oil press light 23 brown/grey
6 green/white Fuse 9- Oxygen sensor relay 22 green/white
7 green ign switch - switched power 21 green
8 white/black pin 11 blue plug inst cluster- fuel rate input 24 white/black
9 black pin 7 blue plug inst cluster- engine speed input 20 black
10 blue pin 20 check panel- dynamic oil level 2 blue/yellow
11 white/green pin 22 blue plug inst cluster- reset service lights 19 white/green
12 grey Check Engine indicator 8 grey
13 green/purple fuse 11- fuel pump relay 13 green/purple
14 black/white pin 10 white plug inst cluster- speed signal out 14 black/white
15 black/green pin 1 blue plug inst cluster- from unloader relay 15 black/green
16 white/black Diagnostic connector pin 6 17 white/purple
17
18 black/yellow ign switch- start 18 black/yellow
19
20 red/yellow ABS power 3 red/white
M52B28
wiring for an E36 M52B28 into an E30
Pin # C101 Colour Goes to.. on E30 Connect to Pin # M52B28 engine plug
2 blue/black Pin 16 check panel - static oil level if fitting oil level sensor, connect here
3
4 brown/purple pin 26 blue plug inst cluster- temp gauge 12 brown/purple
5 black/brown pin 18 blue plug inst cluster- oil press light 23 brown/green
6 green/yellow Fuse 9- Oxygen sensor relay 22 green/white
8 yellow/white pin 11 blue plug inst cluster- fuel rate input 24 white/black
10 purple/green pin 20 check panel- dynamic oil level if fitting oil level sensor, connect here
11 white/blue pin 22 blue plug inst cluster- reset service lights 19 white/green
12
13 purple/red fuse 11- fuel pump relay 13 green/purple
14 blue/yellow pin 10 white plug inst cluster- speed signal out not connected
16
17
19
20 brown pin 20 blue plug inst cluster- ground not necessary to connect
Comments
Unused Wires
Econometer
