M5x
The BMW M5x range of engines are a line of 6-cylinder engines, fitted to BMW models between 1991 and 2001. The range is comprised of three main units; the M50, M50TU and the M52. All M5x engines are fundamentally based on the M20 engine that powered the E30 320i, 323i and 325i, and are therefore very popular engine swaps.
M50
M50TU
M52
| M40B16 | 1.6 L (1596 cc/97 in³) | 75 kW (101 hp) @ 5500 | 143 N·m (105 ft·lbf) @ 4250 | 6200 | 1988 |
| 73 kW (98 hp) @ 5500 | 141 N·m (104 ft·lbf) @ 4250 | 6200 | 1988 | ||
| M40B18 | 1.8 L (1796 cc/109 in³) | 85 kW (114 hp) @ 5500 | 165 N·m (122 ft·lbf) @ 4250 | 6200 | 1987 |
| 83 kW (111 hp) @ 5500 | 162 N·m (119 ft·lbf) @ 4250 | 6200 | 1987 |
Sump Gasket
Piston Head
Piston Rings
Crank Pulley
Despite the three styles of Head, the rocker cover is interchangeable across all M40 engines. It is positioned on 8 studs and fixed with M10 nuts. It has one hole for the Oil Cap, and one port for the breather hose.
Cam
Rocker Arms
Breather Hose
Engine Mounts
