M5x
Revision as of 21:17, 16 November 2011 by Grrrmachine (talk | contribs) (New page: {{stub}} The BMW '''M5x''' range of engines are a line of 6-cylinder engines, fitted to BMW models between 1991 and 2001. The range is comprised of three main units; the [[M5x#M50|M50...)
The BMW M5x range of engines are a line of 6-cylinder engines, fitted to BMW models between 1991 and 2001. The range is comprised of three main units; the M50, M50TU and the [[M52. All M5x engines are fundamentally based on the M20 engine that powered the E30 320i, 323i and 325i, and are therefore very popular engine swaps.
M50
M50TU
M52
Models
M40B16 1.6 L (1596 cc/97 in³) 75 kW (101 hp) @ 5500 143 N·m (105 ft·lbf) @ 4250 6200 1988
73 kW (98 hp) @ 5500 141 N·m (104 ft·lbf) @ 4250 6200 1988
M40B18 1.8 L (1796 cc/109 in³) 85 kW (114 hp) @ 5500 165 N·m (122 ft·lbf) @ 4250 6200 1987
83 kW (111 hp) @ 5500 162 N·m (119 ft·lbf) @ 4250 6200 1987
Sump Gasket
Piston Head
Piston Rings
Crank Pulley
Despite the three styles of Head, the rocker cover is interchangeable across all M40 engines. It is positioned on 8 studs and fixed with M10 nuts. It has one hole for the Oil Cap, and one port for the breather hose.
Cam
Rocker Arms
Breather Hose
Engine Mounts
Useful websites
See also
